Arriva rail London trainee drivers
Discussion in 'Railway Jobs & Careers' started by baz962, 1 Feb 2020.
  1. baz962
    baz962 Established Member
    1,582
    8 Jun 2017
    Rail Forums
  3. Applepie356
    Applepie356 Member
    56
    23 Sep 2019
    Swanley
    Do they require an enhanced pass for their psychometric tests?
  4. baz962
    1,582
    8 Jun 2017
    One of the highest
  5. Aftv49
    Aftv49 Member
    14
    21 Jan 2020
    Can’t find the vacancy. They’ve probably taken it down
  6. Applepie356
    Applepie356 Member
    56
    23 Sep 2019
    Swanley
    Nope, still up. The old Arriva Rail portal is a bit poor on mobile.
  7. JAMES BENGE
    JAMES BENGE Member
    11
    9 Apr 2019
    It's still up, I just applied, good luck everyone.
  8. DA1
    DA1 Member
    94
    22 May 2017
    Kent
    I was told recently they recruit twice a year so bearing in mind the last campaign was July make sure you get in quick. Very competitive. I’ve got my stage 2 coming up for this role.
    Good luck all.
  9. Emz
    Emz New Member
    3
    10 Jul 2019
    I can’t seem to upload my CV. Is anybody else having issues? I’m on an iPad.
  10. OneLowban
    OneLowban Member
    680
    30 Oct 2017
    Under the heading ‘Search Openings’, click on the ‘search’ button and it shall appear.
    Not sure if it’s the reason for your problems but I would always use a computer if possible for applying.
  11. Emz
    Emz New Member
    3
    10 Jul 2019
    Yep I’ve gone onto a laptop. Thanks for your reply
  12. Sammy2019
    Sammy2019 Member
    46
    22 Sep 2019
    Essex
    Thanks for the heads up mate I’ve applied.
    does anyone know how strict they are on locations? It says on the website that you must live within an hour of the depot. Depending on the time I travel and route I take it could be anywhere from 45 minutes to an hour and a half a according to google maps.
  13. TBDDesiro
    TBDDesiro Member
    31
    14 Jul 2019
    I’ve applied hopefully better than July opening (paper sift rejection).
    on another note anyone notice the email comes from “invalidemail.com”?
  14. mresh91
    mresh91 Member
    129
    30 Aug 2013
    That's just a generic handle the database uses when sending out bulk e-mails.
  15. James71
    James71 Member
    35
    5 Aug 2019
    Applied. I did apply in the July one but since then I've sat my psychometric and passed so hopefully that helps a little!
  16. DanielAg
    DanielAg Member
    32
    26 Jan 2019
    Cheers for that.. application has gone in however I’m exactly a hour travelling time away which could obviously change throughout the day.. worth a shot I guess let’s wait and see!
  17. Teddyward
    Teddyward Member
    389
    3 Oct 2017
    Thurrock
    Stuck one in. First time failed vse. Second time didn’t get a reply even for sift. Third time lucky lol?
  18. Quin79
    Quin79 Member
    194
    11 Mar 2019
    I've put my name in the hat for this one too. I'm not sure how rigid they are on the 1 hour travel time stipulation. I'm about 7 mins out of the 1hr from Willesden and 9 mins out from the New Cross Gate. I did put however that am going through divorce so will be moving soon and will ensure will move to meet the criteria.....time will tell
  19. Jaytrains
    Jaytrains Member
    138
    20 Nov 2017
    It’s not letting me apply -___-
    Can’t find a button that says apply
  20. OneLowban
    OneLowban Member
    680
    30 Oct 2017
    - Click link
    - Scroll down to under the ‘search openings’ heading
    - Click search
    - Choose location
    - Scroll down and click ‘apply for this position’
    I can see that on my mobile so you should be seeing it with those steps above.
  21. Jaytrains
    Jaytrains Member
    138
    20 Nov 2017
    Thanks
    i clicked on “Add to jobs” because i logged in already so it cane out different
  22. Jaytrains
    Jaytrains Member
    138
    20 Nov 2017
    Came**
  23. Lenny_U
    Lenny_U Member
    26
    8 Aug 2019
    Hi everyone, I have also applied for Willesden Green depot. Last year I went for Crossrail, but failed my DMI in October and I was told I could apply again in 6 months. How does it work though? Do they count 6 months from when you first applied for job or from when you failed? I first applied for Crossrail in May last year. Can anyone help? I applied with Arriva anyway, hoping 6 months would be counted from when I first applied with Crossrail.
  24. Teddyward
    Teddyward Member
    389
    3 Oct 2017
    Thurrock
    The DMI does not count as a fail for other companies.
  25. OneLowban
    OneLowban Member
    680
    30 Oct 2017
    The 6 months is counted from the fail.
    But yes, as above, DMIs only count for that TOC so you are fine to apply for Arriva.
    It’s only the psychometric tests that you have to wait 6 months to do again, regardless of TOC.
  26. Celrocks
    Celrocks Member
    10
    28 Jul 2019
    Hi guys
    Has anyone got any reply or any email after applying . I applied but haven’t got any confirmation email. Is it normal or did I do something wrong?
  27. Itchy_Butt
    Itchy_Butt Member
    17
    15 Jul 2019
    Maybe check your junk mail? I got a confirmation straight away
  28. Celrocks
    Celrocks Member
    10
    28 Jul 2019
    Thanks
    I just emailed them .. did you get any assessment or just the confirmation.
  29. Itchy_Butt
    Itchy_Butt Member
    17
    15 Jul 2019
    Just the confirmation for now
  30. Lenny_U
    Lenny_U Member
    26
    8 Aug 2019
    Thank you!!!
  31. Lenny_U
    Lenny_U Member
    26
    8 Aug 2019
    Thank you!!!
Share This Page
