Arriva UK new buses 2019
Discussion in 'Buses & Coaches' started by Josh Lawson, 17 Feb 2019.
  1. Andyh82
    Andyh82 Established Member
    1,570
    19 May 2014
    Is 2005 a limit though?
    Now DDA is out of the way, I think we will go back to buses lasting 20 years.
  2. Josh Lawson
    Josh Lawson Member
    40
    18 Oct 2018
    Rochford, Essex
    I heard they were aiming for 15 years but that mite have changed.
  3. TheGrandWazoo
    TheGrandWazoo Veteran Member
    11,921
    18 Feb 2013
    Depreciation is a MINIMUM of 15 years straight line
    The life will be more depending on the type.
  4. Arctic Troll
    Arctic Troll Established Member
    9,801
    12 Sep 2013
    Newcastle upon Tyne
    There's nothing wrong with older buses if they're looked after. And some of the older Arriva buses have been looked after for instance the W-reg ALX300s up here.
    The trouble is that many of the older buses are cascades from London. London is not kind to buses. E-leather seats and MAX branding doesn't disguise it.
  5. Josh Lawson
    Josh Lawson Member
    40
    18 Oct 2018
    Rochford, Essex
    Ah that makes sense, i think Double Deckers usually last the longest.
  6. Robertj21a
    Robertj21a Established Member
    5,551
    22 Sep 2013
    It's more likely to be the chassis type - Volvo, Scania etc (as long as the bodywork is a 'quality' make too)
  7. DavidGrain
    DavidGrain Member
    811
    29 Dec 2017
    When you say £1bn for the whole company are you just referring to the UK operations? If DB sell Arriva I would expect them to sell the entire company which in the year to December 2017 had operating profits of €569m
  8. DavidGrain
    DavidGrain Member
    811
    29 Dec 2017
    NEx WM are still operating buses with BU51 registrations although I don't think here are too many still in service
  9. Arctic Troll
    9,801
    12 Sep 2013
    Newcastle upon Tyne
    You don't tend to see lightweight double deckers in the same way you see lightweight single deckers.
    There are so many variables, you're quite right though. Even with chassis, it depends on bodywork manufacturer; Plaxton Pointer bodied Darts lasted in a way the Marshall and Caetano ones never did.
  10. WM Bus
    WM Bus Member
    90
    28 Jul 2018
    Yes. Some at West Bromwich and 4276 - 4291 are those expected to remain in service after this current round of changes. They could remain in service for a while yet it seems, with these being trapped and Euro 6, so they have no intention of getting rid of them yet. As they will be required next year with the Birmingham Low Emission Zone being increased to a restriction of Euro 6 vehcicles in 2020.
    These B7TL ALX400 are also the only double decks that can be used on the 5/73 other than the E400 MMC, due to a height restriction on the 5 in Hall Green and the 73 interworking with the 5. So that's where 4276 - 4291 are usually found.
    Also 4177 (which is a Y reg Trident) was still out on the 60 yesterday. This one can't have very long left now.
  11. Josh Lawson
    Josh Lawson Member
    40
    18 Oct 2018
    Rochford, Essex
    Arriva Southend have a number of 02, 52 & 03 reg Cadets and Lowlanders still in service.
  12. Josh Lawson
    Josh Lawson Member
    40
    18 Oct 2018
    Rochford, Essex
    StreetLites 4224, 4261 & 62 from Southend have been swapped for Volvo Eclipses 3818, 19 & 26 from Colchester. Also there is an Optare Metrocity on loan to Arriva Guildford.
  13. Hophead
    Hophead Member
    884
    5 Apr 2013
    Look out for Arriva's minibuses. Showing the kind of professionalism you've no doubt come to expect, Arriva have published the following:
    Sevenoaks local services 1 and 2 from 7th April 2018
    Start Date: 07/04/2019
    If the minibuses head your way, you'd be well advised to start looking for alternative travel plans, given the havoc these vehicles have wreaked so far on their trail of destruction across Surrey, Sussex & Kent.
  14. Josh Lawson
    Josh Lawson Member
    40
    18 Oct 2018
    Rochford, Essex
    I hope they don't come to Southend.
  15. Bungle965
    Bungle965 Established Member
    2,429
    2 Jul 2014
    Blackley and Broughton/ Walsall South
    Still a few of the Caetano ones knocking about, the Marshall ones have as you said died out completely.
    Someone mentioned Scania earlier on, the OmniCity's which were assembled in Poland aren't much cop it has to be said.
    Sam
  16. 83G/84D
    83G/84D Established Member
    4,221
    28 Oct 2011
    Not too far from goongumpas treacle mine!
    Can anyone shed any light on what routes the Derby based Streetlites operate?
    On two visits to Derby bus station I only saw a small number of them despite waiting around for several hours.
    Any assistance would be appreciated.
  17. Robertj21a
    5,551
    22 Sep 2013
    They run the routes that start at The Spot (the 'other' side of that shopping centre).
  18. 43055
    43055 Member
    580
    8 Mar 2018
    The only route that they are likely to turn up on at the bus station is the P&R. The other routes that are almost always Streetlite operated is the 5/5A & 7 which go from The Spot/Babington Lane or the 8 & 9 which start from Albert Street.
  19. APT618S
    APT618S Member
    34
    7 Dec 2018
    When I have been in Derby I have seen the Arriva Streetlites on the 8 & 9 from Albert St, and as stated above on various services that run from the Babington Lane / St Peters St / Osmaston Rd loop which is the other side of the shopping centre.
  20. 83G/84D
    4,221
    28 Oct 2011
    Thank you everyone.
  21. Javelin700
    Javelin700 Member
    11
    12 Nov 2018
    Several of Gillingham's E200 mmc's are being repainted into Fastrack livery and are being subsequently transferred to Northfleet with several of there 15reg streetlites moving to Gillingham in exchange.
  22. Murray J
    Murray J Member
    35
    10 Aug 2019
    I believe arriva southern counties just got a batch of 4 new streetlites for Hemel Hempstead. Slightly weird because Hemel Hempstead has fairly modern buses compared to other depots. The only fairly old buses are an '03 Wright cadet, '04 solo and a bunch of '07 plaxton centros.
  23. Robertj21a
    5,551
    22 Sep 2013
    Well, an 03-reg is 16 years old and similar buses are being withdrawn elsewhere.
  24. Mwanesh
    Mwanesh Member
    424
    14 May 2016
    About time Hemel and Stevenage had new buses for the 300/301 Centraline. The Enviros have been hammered for 10 years on than route. They are falling apart.
  25. class387
    class387 Established Member
    1,397
    9 Oct 2015
    Probably won't happen before the route is split next month unfortunately.
  26. plebb11
    plebb11 Member
    8
    26 Jun 2014
    Bedfordshire
    Hopefully it will make the 300/301 more reliable by splitting the service, new Streetlites are due in Hemel for services 300/302
  27. Javelin700
    Javelin700 Member
    11
    12 Nov 2018
    Gillingham are due to recieve 13 sapphire spec Wright Streetdecks this autumn for service 101 with the existing E400's transferring to other Kent based depots.
  28. spuddie
    spuddie Member
    118
    20 Aug 2013
    I've seen some of the new Streetlites in Hemel today already on service 4, surprisingly if they are for the 300/302 they are only short version ones, would have thought would have needed a bit more capacity unless the Hemel - St Albans section is light loaded?
    Also noticed Hemel have got some ex Tower Transit ex First small Enviro 200's.
    Quite surprised to hear about the 300/301 changes, in some ways I hope it works but a bit sad that the number 300 is only being used for the short route between Hemel and St Albans.
  29. class387
    1,397
    9 Oct 2015
    Are the new buses to standard Arriva spec or something a bit more luxurious?
    Agreed about the 301 changes - I would have thought to keep the long routes as 300/301 and make the 302 the new short route.
  30. 321001
    321001 Member
    8
    20 Jan 2012
    Hemel Hempstead
    Had a ride from Grove Hill to Marlowes earlier and I thought it was a pretty decent bus.
    Didn't get a chance to experience it in the other direction to see what its' hill climbing abilities are.
    Don't know if they've fitted wifi to the buses it wasn't switched on if they have.
Share This Page
