Sure rgetee
Using a GPS and a stopwatch is a reasonable measurement ?
And if you’re using a GPS there’s probably no need for a stopwatch!
Sure rgetee
Indicative, I should have written. Unless you have a way of knowing the driver is full notch 0-60.Using a GPS and a stopwatch is a reasonable measurement ?
Thanks for the knowledge mate12 car 375s automatically derate to avoid overloading the current supply (at least they did a few years back when I was briefly driving them with a DI). 12s were noticeably more sluggish than 8s, especially on the looong climb out of Rochester towards London on the Chatham mainline.
Between Ashford & Folkestone West it's not bi-directional is it? Yes signals are there but they are covered over.Yes and yes. Bidirectionally signalled lines are almost invariably slower in the 'wrong' direction in order to keep costs and complexity down. Where there are differential speed limits, the upper limit applies to any train that doesn't match the lower category/ies.
Simon
Unless something has changed in the last year or so where I haven't been that way, it's still bi-directional between Dollands Moor and Ashford. There are covered up signals in the Folkestone area dating from when 4 tracks existed here until the late 90s when they were cut to 2, reflecting the closure of Dover Marine/Western Docks and the Channel Tunnel opening.Between Ashford & Folkestone West it's not bi-directional is it? Yes signals are there but they are covered over.
Simon
Which you can't know. You can make educated guesses based upon:Indicative, I should have written. Unless you have a way of knowing the driver is full notch 0-60.
Hence why I keep reiterating that, as long as mechanical specification is broadly the same, the difference in rate of acceleration between subclasses is minimal.Even those methods aren't reliable.
Given that most of my work assignments so far have concerned Cl377/379 (which, of course, are not relevant to this discussion), I'll concede that I'm not as familiar with the Cl375!You are correct of course but when I’ve struggled to get a 375/9 up to 100 mph before braking for the Westenhanger stop and a 375/6 easily achieves this before Herringe its very obvious. You only get 8 minutes from Ashford so it’s full power all the way
If you mean it takes a 375 8 minutes to get from Ashford to Westenhanger, you are implying a Javelin takes 8 minutes to reach just 85mph (assuming you meant 6 car formation). I don't know if a Javelin could ever get to 100 on level track.You are correct of course but when I’ve struggled to get a 375/9 up to 100 mph before braking for the Westenhanger stop and a 375/6 easily achieves this before Herringe its very obvious. You only get 8 minutes from Ashford so it’s full power all the way
