Assessment practice material from TOC?
amanda08
19 Oct 2019
blackpool
I’ve seen mentioned many times on here, about people receiving assessment practice material from HR.
My assessment with EMR was confirmed nearly two weeks for 20th November, but I’ve not received anything to practice with? Is this likely an oversight or SOP? Not sure whether to drop HR an email but don't want to get a reputation for being as pain in the a** before I’ve even stepped foot in their door!
Stigy
6 Nov 2009
Were you sent an email with any attachments when they invited you? Sometimes they’re not the clearest of correspondence (the railway as a whole). Might also be worth checking your junk email folder? There’s usually some guidance within any email correspondence. If not, give them a call?
34fh0131
25 Jun 2019
Is this for a Driver role? If so, they would normally have sent the paperwork out before your OPC stage 1 day.
Worth checking your junk Email though as mentioned by Stigy
Supertrains19
18 Apr 2019
Worcester
Worth also noting if you don’t get the Ora rice material you will be asked as part of the initial sign in and acceptance of the assessment if you have had and used the practice material, if you say no you will be encouraged not to take the assessment so I would try and get it sorted ASAP.
amanda08
19 Oct 2019
blackpool
Its for Train Manager, so i'm not 100% sure what tests there will be on the day, beyond Scaat. I will drop them an email now,. Thanks
