Attempt to cover all lines in TFL oyster area
silverfoxcc
17 Apr 2012
The remit is to travel over all the lines that are shown on the 'London Connection/TFL Oyster card area and have a regular passenger service.and not just pass through a station to complete.but both up/down directions
The one allowance we have given ouselves is that where there are multiple tracks eg Hackney Downs/Liverpool Street and Stratford/LS then any will cover
however there are a couple of 'routes' shown that i am having problems finding services
These are
The Ladywell loop
Slade Green-Barnehurst curve
Slade Green-Crayford loop
Rail planner app doesn't dem to help. Anyone in the know can assist?
Thanks
W-on-Sea
18 Dec 2009
Have a look here
http://www.psul4all.free-online.co.uk/2016.htm
e.g. the one I looked up (Slade Green to Barnehurst) reveals "Slade Green Junction - Perry Street Fork Junction (200) WC02
Shown as "limited service" on London & South East schematic map, but has regular service ca. 0800 SuX until 1800 SuX between Barnehurst and Slade Green.|"
Info on the other two routes you mention should hopefully be available there too
postye
7 Feb 2013
These are
The Ladywell loop
Thanks
Spade Green - Crayford and vice-versa is served by all direct trains from Sidcup - Woolwich Arsenal that do Cannon Street - Cannon Street via Woolwich/Sidcup.
There are generally 2tph in either direction on all days subject to engineering works
mister-sparky
28 Jan 2007
Kent
These are
The Ladywell loop
Thanks
all 3 of those are served by 2tph at least off-peak on weekdays, so you should definitely not be having any trouble finding services...
ComUtoR
13 Dec 2013
What about the Tonbridge fast loop or both the Chatham loops ?
ComUtoR
13 Dec 2013
Orpington isn't in the Tfl Oyster area ? Neither is St Mary Cray ?
ComUtoR
13 Dec 2013
I know. I suspect that Busaholic didn't know where those loops were. <D
30907
What about via Stewarts Lane? I know it won't be shown on any public map, but it's in the area? Several trains booked UP but only one DOWN if I read PSUL rightly.
Kite159
27 Jan 2014
West of Andover
Although isn't the only services which use those loops are peak time services from Cannon Street towards Rochester, which run fast to Rochester after London Bridge (if I'm thinking about the right loops, so many different names around the point where the Chatham main line goes underneath the South Eastern Main Line)
ComUtoR
13 Dec 2013
What about via Stewarts Lane? .
Good call.
What about Canterbury Road & Atlantic lines into and out of Vic ?
PSUL ?
Which would count as regular services. ;)
If you are going to add every possible odd move PSUL mentions then why not the regular (but infrequent) SWT services over the District line?
But we don't actually need to go there because the original poster's question clearly defined the problem in terms of lines shown on the Oyster rail services map...
bb21
Emeritus Moderator
4 Feb 2010
Up Chatham Loop cannot be done on Oyster PAYG despite being inside the area. Reversible loop is frequently used on engineering weekends, in both directions, with trains calling at St Mary Cray.
Fast Tonbridge Loop can be done on Oyster on several services, the most convenient being the 1940 ex-Victoria weekdays iirc. Trains terminating at Orpington tend to use the Slow Tonbridge (Petts Wood Pfm 3/4).
As the poster above me pointed out, it is straying off topic. Can we open a different thread if people want to discuss PSUL moves in general please?
