Pakenhamtrain
From The ABC
The fault is with the replacement engines on 3000/3100 class railcars. An issue with the turbo in them.
In the time since they've gained back 8.
Passengers cram onto Adelaide trains following fault, despite social distancing requirements
The number of Adelaide rail services currently operating has been slashed after a mechanical fault was identified, resulting in remaining trains becoming packed with passengers.
Fifty of the 70 diesel engines have been taken out of commission for inspection after a problem was reported on Wednesday.
Services on the Outer Harbor, Gawler and Belair lines will now run half-hourly, while Grange rail services are being replaced by buses.
Fifty trains out of service as fault forces Adelaide passengers to 'pack like sardines'
The number of Adelaide rail services has been radically reduced after a mechanical fault, with remaining trains becoming packed with passengers apparently in breach of social distancing.
www.abc.net.au
