Not yet..Anyone heard anything?
What they say ?Got an update today
That they would like to progress my applicaion, however they're not sure when the next stages will be due to the current Covid 19 situationWhat they say ?
Well doneThat they would like to progress my applicaion, however they're not sure when the next stages will be due to the current Covid 19 situation
Me too ditto email!!Got an update today
Thank you i hope you get the same email tooWell done
Does anyone know if the Psychometric tests for this position would be the same as what you do for normal TOC's? And if they're to national standard or enhanced? Thank you
Thank You for your helpThey would be the same as it’s a requirement for all trainee train driver roles. Not sure but at a guess, standard should be enough.
No, you?As above transit moves needed to put machines in place for weekly and weekend work sites.
What are SOL's? ThanksWorth keeping in mind OTM drivers unfortunately often have SOLs which remain on their file and can effect future jobs with FOC or TOCs.
Plenty of RAIB reports on the fact.
SOL I believe means 'Safety of the Line'What are SOL's? Thanks
Thank you.SOL I believe means 'Safety of the Line'
A SOL would invariably be an incident relating to the infraction of safety on the line
Thank you for the heads up that is exactly what I wanted to doAlso to add, your probably drive your machine over routes you don’t sign. You’ll be route conducted by driver spot hire operators like West Coast Rly Co, your putting your license in the hands of others with sometimes very questionable competence.
This really isn’t a job for someone who is looking solely for a key, then to move on.
Unless you get your kicks in A&R department of course !
So your saying if you move to a toc you will do these unauthorised out of habit from doing it Authorised in the OTM role?Safety of the line incidents, SPADs, point run thoughts, crossing over level crossings without authority, leaving a possession without authority, unauthorised wrong direction movements, derailments, collisions etc.
You’ll be most of those with authority - minus the collision, spad and derailment within posssisions as routine hence why it’s so easy to fall into the trap.
I think no.So your saying if you move to a toc you will do these unauthorised out of habit from doing it Authorised in the OTM role?
I assumed (and as such may be wrong), he was saying because you’re making all these moves at an OTM Driver, there’s more chance of an incident because of this, in that role. Although I guess it works like that in both cases through habitually doing something and then having to do something else?So your saying if you move to a toc you will do these unauthorised out of habit from doing it Authorised in the OTM role?
Nail on the head yes.I assumed (and as such may be wrong), he was saying because you’re making all these moves at an OTM Driver, there’s more chance of an incident because of this, in that role. Although I guess it works like that in both cases through habitually doing something and then having to do something else?
