Barrier codes
Larry Trapp
18 Nov 2018
wasn’t sure where to put this so mods please feel free to move this if necessary.
Is there a list anywhere of what the barrier “Seek Assitance” error codes mean ?
Just interested.
Thanks.
6 May 2017
Near a bunch of sheds that aren't 66s.
Just interested.
Thanks.
Usually means that there is an issue with your smart card or contactless Bank card and you will need to speak to a member of staff about this.
sharpley
18 Aug 2018
List of POD (Passenger Orientated Display) Codes for gates made by Cubic... Includes TOC & TfL mag ticket, Oyster, Contactless, ITSO & barcode reject codes
00 - Valid Ticket / Card
01 - BAD TABLE - Invalid Table Data
02 - TYPE/DIR - Wrong ticket type or direction
03 - TYPE OOR - Ticket type out of table’s range
04 - CHK ERROR - Check table error
05 - TEST MODE - LUL Mag Ticket Checking & NTMs: Revenue Ticket / Card presented in Test Mode TOC Ticket Checking: Test Mode ticket
06 - NOT TST MD - LUL Mag Ticket Checking & NTMs: Test Ticket / Card presented in Revenue Mode TOC Ticket Checking: Engineer Signed On
07 - UNREAD TK - Ticket magnetic code unreadable
08 - VRF FAIL - Ticket re-coding error (when a THU tried to write code to ticket)
09 - INVAL CHK - Ticket code read error
11 - DATE EXP - Ticket / Card Expired, Barcode: Expired/Out of Date
12 - TIME O DAY - Not Valid at this time
13 - EXCESS - Excess to pay
14 - HR NO ACC - Ticket not valid, and no applicable excess
15 - NO ON VAL - No onward validity (ticket valid for station, but not for further travel)
16 - OUT ZONE - Not Valid at this Zone
17 - NOT ISS HR - Not issued here (attempting entry with a ticket issued elsewhere)
18 - INVAL STN - Not valid at this station
19 - NOT YET VL - Not yet valid (date), Barcode: Future Dated
20 - EXPIRED - Card Expired
21 - DOUBLE ENT - Double Entry attempted
22 - DOUBLE EXI - Double Exit attempted
23 - CARNET NVL - Carnet Ticket not yet validated
24 - LOW SV-NZ1 - Insufficient SV. TKT not zone 1
25 - NOT ENTERD - Unstarted Journey - Exit not permitted
26 - SM ENT EXT - Entry and Exit at same Station
27 - TNP DIS ZN - T&P not enabled for this Zone
28 - SV DISBLD - SV Disabled
29 - PPT DISBLD PPT - Disabled, Barcode: Ticket Type Not Valid
30 - CARD DIS - Card Disabled
31 - F INV OSI - Illogical interchange through barrier (illogical route)
32 - TO INV OSI - Illogical interchange through barrier (illogical route)
33 - ILLOG OSI - Illogical interchange through barrier (illogical route)
34 - EXT DISALL - Exit not allowed
35 - LOW SV-Z1 - Insufficient SV. TKT zone 1
36 - LOW SV - Insufficient SV. No TKT
41 - PASSB THRU - Pass back through / Zig-Zag: Attempt to Enter after an Entry and Exit at the same station; or attempt to Exit after an Exit and Entry at the same station.
42 - PASSB OVER - Pass back over: Attempt to Enter after an Exit and Entry at the same station; or attempt to Exit after an Entry and Exit at the same station
43 - INVAL PSNG ITSO - Invalid number of passengers in an IPE(Num adults+Num children + Num concessions <>1)
44 - NO RIDES ITSO - There are no rides remaining on an IPE where that IPE is the only valid IPE on the card.
45 - INVAL IPE ITSO - Invalid IPE field value.
46 - INVAL ENTL ITSO - Valid Entitlement on card doesn't provide free travel (needs STR to go with it).
47 - IPE SEAL ITSO - IPE Seal Error
48 - ITSO ICHGE ITSO - Too Long on Interchange
49 - ITSO TR TL ITSO - Too long on Tram-Rail Interchange
50 - ITSO TR NA ITSO - Tram-Rail Interchange not allowed here
51 - ALRDY USED - Ticket has already been used
52 - BLACK PASS - Blacklisted staff pass
53 - BLACK PERM - Blacklisted travel permit
54 - ENIGMA - Valid ticket, but only for a journey shorter than that travelled
55 - USED JOURN - Ticket has already been used for journey
56 - OUTOFTERM - Scholar Pass out of term
57 - PPT INVLD - Location not covered by PPT, Barcode: NLC not valid
58 - ITSO ZONES ITSO - Insufficient Zones
60 - ITSO OSI ITSO - Too long on OSI
61 - LONG OSI - Too long at interchange (unexpectedly long time spent changing stations during journey)
62 - LONG JOURN - Too long on journey (unexpectedly long time spent between journey start and end)
63 - LONG PLAT - Too long on platform (unexpectedly long time spent on platform, with a platform ticket)
64 - LONG XCESS - Too long on excess (unexpectedly long time spent between journey start and end, for which the excess applied)
65 - ENT TIM XC - Ticket entry time limit exceeded
67 - CPC DECLINE - Payment Card Declined
69 - CPC DECLINE - Payment Card Declined
70 - PRSNTN ERR - Unspecified NTM Presentation Error
71 - TOO MANY - Multiple NTM Cards Presented
73 - EMERG INV - Emergency ticket, not valid for travel at this station.
74 - CARD BLOCK EMV - Payment card is blocked by transport authority
75 - OYST UNSUP - Oyster Card Capability is unsupported
76 - PAYC UNSUP EMV - Payment Card Capability is unsupported
77 - ITSO UNSUP ITSO - ITSO Card Capability is unsupported
78 - UNKN PCARD EMV - Unknown Payment Card Type
79 - VAL FAIL EMV - Payment Card Validation failure
80 - ISSR BLOCK EMV - Payment Card is blocked by issuer
81 - GROSS OVER - Illogical use of ticket
82 - INV HIST - Illogical use of ticket
83 - INV TIME - Illogical use of ticket
84 - INV GEOG - Invalid geography
85 - PCARD EXPD EMV - Payment Card expired
86 - AID BIN EMV - Payment Card has an invalid AID or BIN
87 - TXN TIMOUT EMV - Payment Card Transaction timeout
88 - WRONG TYPE - Wrong System Type
89 - CARD TYPE - Unknown Card Type
90 - REJECT MON - Rejecting monitored ticket
91 - NOTYET VAL EMV - Payment Card not yet valid
92 - CARD DIR - Card Directory Corrupt
93 - CARD CONT - Card Contents Corrupt, Barcode: Decryption Error
94 - CARD COMMS - Card Communications Failed, Barcode: Server Comms. Error
95 - PROC FAIL EMV - Payment Card processing failure
96 - RDR INIT - Reader Init Failed
97 - REM EARLY EMV - Payment Card removed early
98 - AUTH REQD EMV - Payment Card requires online authorisation
99 - CHK TIME - Ticket checking took too long to complete.
100 - DELIVERY TOC - Ticket was issued in delivery mode
101 - TECH TOC - Ticket was issued in technician mode
102 - TRAINING TOC - Ticket was issued in training mode
103 - BAD TDATA - Invalid data was found on TOC ticket
105 - XX INV - Invalid TOC type ticket.
106 - XX REJECT - Always to be rejected.
107 - XX TTTT - Time restraint applied to this TOC ticket type.
108 - PP TTTT - Time restraint applied to this TOC passenger type.
109 - XX TTTT - Time restraint specified by LUL data on TOC ticket
111 - XX ZONES - TOC Ticket is not valid in this zone.
112 - XX DDMMYY - Single/return TOC ticket not valid until date shown.
113 - XX DDMMYY - Single/return TOC ticket not valid after date shown.
114 - XX DDMMYY - Season/rover TOC ticket not valid until date shown.
115 - XX DDMMYY - Season/rover TOC ticket ceased to be valid after date shown.
116 - XX OOOO - Station not listed for Entry / Exit with this TOC ticket.
117 - XX DDMMYY - TOC ticket ceased to be valid after date shown.
118 - XX DDMMYY - TOC ticket is not valid until date shown.
119 - XX DDMMYY - TOC Pass is not valid until date shown.
120 - XX DDMMYY - TOC Pass expired on date shown.
121 - XX PZ - TOC Pass not valid here.
122 - XX YY - LUL ticket is not valid.
123 - XX ROUTE - TOC ticket prohibits this route at this station.
124 - PP PASNGR - Passenger type not valid, or always rejected, for this TOC ticket
125 - XX DDDD - TOC ticket Destination is not valid for exit here
126 - XX OOOO - TOC ticket Origin is not valid for entry here.
127 - XX DDMMYY - TOC ticket wrong date
128 - XX LLLL - LUL Station Only
129 - XX TOC - ticket wrong direction
130 - XX SSSS - LUL Station Only
131 - XX FFFF - TOC Ticket has Insufficient Fare
132 - XX - LUL Route
133 - XX TTTT - TOC ticket Pass-back Timer not yet expired
134 - XX DDMMYY - TOC Ticket has expired
135 - XX RR - TOC Special Rules (Magnetic and ITSO)
136 - XX TTTT - TOC Ticket type direction of travel time restriction
137 - XX TTTT - TOC Passenger type direction of travel time restriction
Metal_gee_man
28 Oct 2017
I've just had a code 125 at Victoria and a 126 at Euston, what so silly is my ticket isn't an anytime any route ticket to Wolverhampton its a fully itineraried advance ticket with reservations, what's even weirder is it didn't have a problem letting me through LU barriers so I give up trying to understand what the hell the ticket data was telling the barriers
Hadders
27 Apr 2011
It could be deliberately programmed like that to force a manual inspection of Advance tickets. The barriers at Stevenage station reject every Advance ticket so they can manually check them. I've stopped trying them now and just go to the person manning them to get through.
Aictos
28 Apr 2009
It's not just the advance tickets though, travelcards have the same issue as I get Error 09 at every GTR barrier yet I don't with Greater Anglia or TfL...
The Travelcard in question is a Super Off Peak Travelcard with a Network Railcard discount which I use on weekends, been told that it's the encoding stripe is bent, that GTR has never got the barriers to accept these tickets etc...
As to the kind member sharing the error codes, thank you!
apinnard
2 Aug 2017
Kettering
The barriers at Bedford and Huntingdon are set to disallow the child tickets that have been bought as part of a child flat fare on Thameslink. I think it's so they can be manually inspected.
Dan A
6 Jun 2018
It might be set to reject any Railcard tickets. I get stopped at gatelines randomly with my smartcard and also with paper tickets for manual checks, because I have a railcard-discounted ticket they want to check I am travelling with my railcard (Ironically, when I'm travelling using my smartcard they never bother to really check the ticket properly).
Chris999999
22 Jun 2010
The problem with rejecting so many valid tickets is that the manual inspection is not done. The person supposedly doing the checking just lets anyone with a piece of cardboard that vaguely resembles a ticket through the manual gate.
Aictos
28 Apr 2009
Thing is GTR constantly tells me it’s because the encoding strip is at fault as it’s unreadable yet works fine on TfL and Greater Anglia gatelines so why is that?
Scott1
29 Apr 2015
Error 09 is the gate failing to read the magnetic strip on the ticket. This is almost always a demagnetised ticket, often if the ticket has been near something else giving off a magnetic field, such as certain mobile phones or contactless card readers. Error 07 is often the same thing, and happens when the gate is reading the magnetic strip but doesn't understand the information, often this is because the strip was not processed correctly by the previous gate or it has not read it correctly, this error will sometimes go away simply by trying again. Some barriers are better than others too, which seems odd but as the readers are essentially mechanical they are subject to wear and tear.
