Basingstoke to Kingston
Starmill
Fares Advisor
18 May 2012
Bolton
It appears that SWR's website is not capable of finding any journeys from Basingstoke to Kingston. The problem affects all Webtis sites by the looks of it. It would appear that it will not permit you to double back between New Malden and Clapham Junction.
It is pretty much impossible to make the journey planner give you an itinerary changing at Surbiton and New Malden because that is so much slower, however you can put via Richmond (which is also much slower but not quite as bad) and that does return results.
This easement may be relevant, or not. It's quite vague:
000012
Journeys from Surbiton and stations west of Surbiton to Kingston upon Thames and stations north of Kingston Upon Thames, may double back between Wimbledon, Raynes Park and New Malden. This easement applies in both directions.
MikeWh
15 Jun 2010
Crayford
The easement only covers half of your intended double-back. Beyond Wimbledon you are asking for Earslfield and Clapham Junction.
bb21
Emeritus Moderator
4 Feb 2010
The intention of the easement is to allow travel on Guildford and Woking stoppers, most of which run fast between Surbiton and Wimbledon. It isn't intended for travel all the way to Clapham Junction.
Starmill
Fares Advisor
18 May 2012
Bolton
So how do people travel from Basingstoke to Kingston? There are almost no services to Wimbledon from Basingstoke, so doubling back that far is useless.
Romilly
5 Nov 2013
If I search for Basingstoke to Kingston on a WEBTIS journey planner such as C2C's, and put Clapham Junction in the "avoid" box, I get lots of journey options for a through ticket with changes at Woking and Wimbledon.
bb21
Emeritus Moderator
4 Feb 2010
I'm not sure that the easement had Basingstoke specifically in mind. Plenty of origin stations can make good use of that easement.
But as Romilly said, you will normally need to change twice on that route, Woking and Wimbledon or Surbiton and Wimbledon or Surbiton and New Malden. I don't know how big the market is for travelling Basingstoke to the Kingston loop, but if the demand exists, I am sure the TOC would be more than happy to clarify the matter, seeing that it undercuts the Clapham Junction fare. ;)
Starmill
Fares Advisor
18 May 2012
Bolton
Travel via Clapham Junction and Richmond is already permitted so there would be no issues going to Clapham Junction. NRE is also satisfied that doubling back between Clapham Junction and New Malden is permitted, but it breaks if you try to pass it through to the SWR site to buy.
NRES seems to permit it, but only with two separate single tickets.
What happened to the old warning icon when more than ticket was needed?
bb21
Emeritus Moderator
4 Feb 2010
Then travel via Twickenham if NRE says it's fine. ;)
Starmill
Fares Advisor
18 May 2012
Bolton
This is less about me and more about SWR's website telling people that this journey cannot be made.
alistairlees
29 Dec 2016
I can get the £19.90 SDS from Basingstoke to Kingston for a search tomorrow at 09.00 to be returned as follows:
TrainGenius (uses Fujitsu journey planner) - one change at Clapham Junction and doubling back via Wimbledon is the default; putting in via Richmond works just as well
Trainline (uses own journey planner) - one change at Clapham Junction and doubling back via Wimbledon is the default; putting in via Richmond works just as well
Hull Trains (using Worldline's journey planner) - will only suggest journeys that are a change at Woking and then at Wimbledon, doubling back from there. This suggests the last valid train in the morning is 07.59. Won't send you via CLJ at all.
NRE (uses SliverRail journey planner) - - one change at Clapham Junction and doubling back via Wimbledon is the default; putting in via Richmond works just as well. I'm not having any problems when being handed off to SWR (Worldline) though
BUT going to the South Western Railway website direct, no results at all!
Conclusion: there's something wrong with the Worldline interpretation of this route (given everyone else can retail it ok).
Kieron Kirk
4 Jun 2017
"That's what I was thinking - Basingstoke to Surbiton then it's a few minutes on the bus. There's a bus (71, 281 and a couple of others) every few minutes."
Buses 71, 281, K1, K2, K3, 281, 465, 514 and 515.
You will need either an Oyster or contactless card.
Kieron.
