So I was doing some thinking whilst driving 313's all day.
Don't worry I'm not going to suggest BEMU 313s .
I did wonder how Bombardier fitted batteries to a 379; seeing as space as limited. It turns out from
this document that they appear to have swapped the MCM from the MOSL and replaced it with batteries. Having driven 377s many times with an MCM out; It's awfully sluggish. Essentially carrying round dead weight requiring the 2 remaining MCMs to do the work of 3.
So my thinking is DC only unit is the better choice. Unless you remove the AC equipment from an AC or DV unit.
Further to this, I was thinking about the systems a bank of batteries have to power...
Take a 4 Car 377 for example: There's 8 Saloon HVACs, 2x ACMs, 3x MCMs, 2 Vacuum Toilets, Saloon environment (Lighting, Plugs, PIS, CCTV), then all the Cab Equipment (In the active cab - inc DOO Systems) and Cab HVAC. It's a fair amount of power.
If it was my project, I'd look at taking 377/3s (Metro Replacement Req) and use these for the BEMU. There's one less coach so therefore; 1 less MCM, 1 Less Toilet, 2 Less HVACs, 1 coach Less of Saloon environment.
So in theory, with the same Battery Bank on a 3 Car vs a 4 Car, you'd get better range as less power is required for the same journey vs a 4 car. At least that's my thinking anyways
A 3 Car 377 would be fine for the current Marshlink Services - Can always be doubled up as required as ASDO is fitted.
On the Uckfield Line they could run 4 units to make the 12 Car for Peaks. And reduce down to 6 Off-Peak. 3/6/9/12 Flexibility.
Food for thought.
