Battery Powered Electrostars for Southern
aleggatta
28 Sep 2015
standard practice these days is that if you go ‘off juice territory’ you should lift or remove the shoes. Just in case.
unless it's a 700... I'm not sure that it's necessarily a requirement that the shoes should lift, but it makes things easier with regards to route clearance?(and protects the shoes when not in use) and to be honest you aren't really making that much more space in the kinetic envelope of the train as the shoe beam is still there even if the shoe is lifted out of the way.
Southern Dvr
13 Oct 2010
The last time SN operated off juice without raising shoegear was 319s to Rugby & Watford. Come every Monday they almost inevitably needed new shoes. It would be very foolish not to ensure the shoes were out the way of any high ballast etc..
Chrisgr31
2 Aug 2011
On the Uckfield line you'll be lifting the shoes clear of deer!
The most important question to me is whether a battery unit can either self recover or be recovered by another battery unit, as otherwise I can see big issues
It's a point I made on another thread in a slightly different context about whether trains on intermittent electrification need twice the battery capacity in case one of the electrified "islands" has gone down. In this case there's a risk that each unit might need getting on for twice the battery capacity in case it has to rescue another one. Perhaps the answer is to say that the rescuing unit has to be one on an outbound journey, so it still has over half its charge, not one that's been to Uckfield and is on its way back.
Energy
29 Dec 2018
Southern have a class 73 which should be able to haul them.
What are you suggesting? Parking it permanently in Oxted bay with a permanent crew and fitting it with new couplers?
Almost certain not to happen.
I should imagine there will be clear operational procedures in place for scenarios if any ‘island’ is off and how to deal with a failed train, such that it avoids providing twice the necessary battery capacity. Fairly straightforward.
For example, rescuing another train doesn’t mean you need twice the battery capacity. Power down the non-critical auxiliaries, and running at slow speed, will give much greater range.
Energy
29 Dec 2018
No, leave it where it is and use it to haul failed units, it will take a bit of time to drive it out their though.
Argyle_mikey
16 Jan 2017
So - best current guesses on what we can expect to replace our much-loved (mostly) 171’s ?
Southern Dvr
13 Oct 2010
Battery power 377s, at least 2 years later than required with another 2-3 years of poor reliability.
Fincra5
6 Jun 2009
Sounds more like a disgruntled passenger rather than any actual facts.
The DfT/GTR were never going to be able to give the 171s over without any replacement. The DfT wouldn't allow it. Even though they don't own the trains... would be a disaster.
Argyle_mikey
16 Jan 2017
Well the chances of any official information being handed out seems pretty remote, doesnt it ? This place seems like our best hope.
Further questions :
1. Anyone know where the conversion of the test unit will take place ?
2. Guesses as to when it might arrive either down here or on the Uckfield line ?
Cheers.
Chrisgr31
2 Aug 2011
Further questions :
Cheers.
We'll know soon enough as there will be delays whilst its recovered! Hopefully it will be tested on 3rd rail track so if it fails it can just connect back to the 3rd rail and move itself!
Argyle_mikey
16 Jan 2017
...which is a particular problem for the Uckfield line should it fail near the country end - unless they install some sort of feed down there. At least with Marshlink it’s a relatively short run with third rail at either end, so you’d hope it could limp home.
Talking of failures, since I suggested the 171’s were “much loved” down here, there’s been a spate of problems. Rye shuttles cancelled again this morning. So perhaps the sooner the better that these are into service, although with four cars, presumably we’ll lose the permanently declassified first class.
Chrisgr31
2 Aug 2011
The 171s do appear to be suffering at present and on the Uckfield line we have had a number of infrastructure failures chucked in as well so it's all been pretty poor recently. None of which though fills me confidence on battery hybrids as their reliability could be even worse!
Anyone heard any more about the unit that is rumoured to be being converted?
Chrisgr31
2 Aug 2011
Incidentally one issue presumably will be that the Class 171s still require guards. The battery hybrids won't. I wouldn't like to be the driver of one of the peak trains that fails at south of Hurst Green as they have to deal with lots of irate passengers on their own!
Fincra5
6 Jun 2009
Depends on which Electrostar gets converted. If one actually does... They will need an OBS if its a 377 for example.
aleggatta
28 Sep 2015
are the Uckfield and Marshlink lines cleared for DOO? I suspect they are, but don't know for sure.
Fincra5
6 Jun 2009
OBS is down to the TOC, not the class of unit, isn't it?
No. If its a 375, for example, it has NO DOO equipment and thus requires a guard. Thats what I was alluding to.
I can't say I know about the Marshlink but then the rest of the Network wasn't DOO cleared, until some NR paperwork was done... :rolleyes:
31 Jul 2010
No extension of DOO was promised so unless the DfT are going to pay for it are they really going to bother? Like said above would you really want to run a train down to Uckfield and it fails without an OBS because of exceptional circumstances. Would be mayhem and it would take a while for the unit to be recovered and so on and so forth. Apparently the replacement units have been confirmed so does anyone know if they are going to definitely be battery powered Electrostars or are they just going to replace them with another diesel variant?
Southern Dvr
13 Oct 2010
I’m still expecting it will be a 158 in and 171 out situation for about 5 years and then some new fangled stuff will be brought in.
NWD_MT97
23 Dec 2019
Uckfield
Uckfield is not cleared for DOO.
Not even ECS which is unusual.
Not exactly true. Yes, DOO (P) services are not cleared for the Uckfield Line. However, DOO (NP) 171 services and certainly Loco only 73's, are cleared.
To quote the General Instruction from the current sectional appendix
"All routes on the Kent and Sussex Routes are cleared for DOO (NP). The only exception is between Appledore and Lydd Town (Goods Line)".
