Battery Powered Electrostars for Southern
Doomotron
25 Jun 2018
Kent
Has the ability to charge the batteries off the dc been improved? If so how?
The problem in the previous appraisal for Marshlink was that the charging in use was far from the state of the art experienced at a tesla fast charger.
The cycle had to be restarted every time the train hit a gap in the third rail and the charging current had to be limited when high power was demanded from the traction motors due to restraints in the dc bus and shoe gear. A continuous cycle of Ashford to Brighton wasn't possible the trains would have run Ashford to Brighton then a return trip to Seaford before running back to Ashford. They hadn't found a feasible solution for the Rye shuttles at that time.
The Eastbourne to Ashford timetable now run would appear to be even worse.
I still say a low cost overhead electrification is the most practical solution.
And would allow Southeastern to run St Pancras to Hastings services.
Milo T.K
10 Mar 2018
There is another option to use NS Talbot DMU stock that recently had been replaced as the Bulgaria deal fell through
supervc-10
4 Mar 2012
Would those fit? I feel like they probably wouldn't.
I kind of feel like what's really needed is 3rd rail electrification, but saving that, a bi-mode 3rd rail/diesel train would be ideal for Southern and to replace SWR's 159s.
LowLevel
26 Oct 2013
They'd never fit the loading gauge in the UK. Far too wide and tall. I believe they're similar to a class 158 mechanically but that's about it
D365
29 Jun 2012
No idea what the article says as I don’t have access! https://www.railwaygazette.com/uk/electroflex-battery-emu-plan-to-end-southern-diesel-operation/55593 however it does appear the 171s are on the way out, May/June next year is when they start going apparently
I don't have access either but it looks like Porterbrook are providing a Class 377/3 for the trial conversion.
I imagine that this will be different to the IPEMU trial in 2015, in that the prototype won't just be developed as a one-off.
Fincra5
6 Jun 2009
Porterbook anticipates than an agreement will be reached soon for Govia Thameslink Railway to release a Bombardier Transportation Class 377/3 Electrostar electric multiple-unit from service so that it can be retrofitted with lithium-ion traction batteries
Wonder if they’ve read my thoughts on it... ;):lol:
Class 170101
1 Mar 2014
Could the Class 377s be interworked though, such that an individual unit would only run on the unelectrified sections once or twice a day separated by several hours until the next visit?
jopsuk
13 May 2008
One would hope that the work from that informs the new conversions, and that with the 171s being off elsewhere this really does need to be a squadron deployment
Fincra5
6 Jun 2009
Not in the current TimeTable.
I wouldn't be surprised if they came along with Tesla Style Super Chargers at Termini, such as; Eastbourne, Hastings and Ashford.
A pantograph could be used as access to the Super Charger. I'm sure ReGen braking can top up the battery level, if 750DC can't, when its being used for the 3rd Rail Operation.
In a similar vain to those seen on some EV Buses. A bit like this.
D365
29 Jun 2012
Vivarail's fast charge system can dump several kWhs into a Class 230 during a seven minute turn around, though admittedly that might not be enough for a Class 377. Plus with fast charging you'd have to take issues like cable amperage and battery charge cycles into account. Repeated fast charging runs the risk of degrading battery performance more quickly, especially if not adequately cooled.
Fincra5
6 Jun 2009
Its interesting as in the Article, Porterbrook seem to be wanting a Fast-Charge Route. Which would fit in with the bare-bones Turn-a-round times on SN!
"The underfloor battery would provide a range of around 60 km, she predicted, with a charging time of 8 min. The intention would be that the battery would never be fully discharged in service, and an emergency mode would provide power to keep onboard systems running for at least 1 h in the event of a train being stranded; Simpson point out that stranded trains don’t need much power."
Brissle Girl
17 Jul 2018
Lets hope Porterbrook has more success in achieving a timely delivery than it has had with its other bi-mode conversion project.
D365
29 Jun 2012
This has the additional benefit of maximising battery life; I was once shown a very interesting graph from a railway battery supplier, which showed the number of cycles in a li-ion battery could be increased dramatically by reducing Depth of Discharge (DoD) to below 80%.
Greybeard33
18 Feb 2012
Greater Manchester
Hmm. Porterbrook's Helen Simpson was behind the 319 Flex project too, making similarly optimistic statements to the press. Maybe lessons have been learnt...?
D365
29 Jun 2012
Also helps that the Class 377s won't be half as rusty.
One would hope...
Chrisgr31
2 Aug 2011
Hurst Green to Uckfield appears to be 31km so they will struggle to do the journey without charging at Uckfield. There is currently an 11 minute turnaround time at Uckfield but fortunately the down trains never run late so they will always have time to charge down there! :D
They also have never been turned round at Crowborough so it all sounds as if it will work really well!
paul1609
28 Jan 2006
Wittersham Kent
Possibly but a much higher proportion of 377/3s would have to be fitted with battery packs.
paul1609
28 Jan 2006
Wittersham Kent
Marshlink trains only have access to Platforms 1 and 2 at Ashford International which are the 12 car dc through platforms. not sure you'd want that sort of thing dangling down. Personally I think theres near to zero chance of this scheme being implemented.
To maintain capacity they are going to have to convert all of the 377/3 fleet anyway.
Any 2-car 171 working will need to be replaced directly by a 3-car 377. A 4-car 171 working will possibly need to be 6-car 377 and a 10-car 171 working will need to be replaced by 12-car 377.
So that is 4 units on Marshlink plus something like 16 units (3 x 4 plus 2 x 2) on the Uckfield line. That is already 20 units. They may as well convert all 28 377/3s.
(I realise there is 377342 as well but that still might revert to 377442 at some point)
hwl
5 Feb 2012
One problem is that most /3s are used for making up 10car metro formations so substantial shortening there unless a /3 is just used as a prototype.
Overall more stock needs to be brought in (or back) though what that is very much depends on what is used for conversion.
Fincra5
6 Jun 2009
Indeed. I'm sure there's plans afoot for the Metro, if 377/3s end up being used totally.
Fincra5
6 Jun 2009
It doesn't dangle down. :s. The pantograph on those buses extends from the roof. It automatically aligns itself to the Charger.
Fincra5
6 Jun 2009
There is also a type where an inductive charging grid does "dangle down" from the bottom of the bus, this type was used in a now-finished trial in MK.
Ah, so there was. That would actually be better I'd say.
You'd have the structures in place at said station's and maybe depot like Eastbourne. The trains are fitted with the relevant connections for the Drop Down Pantograph and the system aligns itself to the train.
Would be cheaper I'd say and faster as each unit would only need "charing pads" rather than a pantograph (for connection) each.
The problem with inductive charging is efficiency or the lack of it (very difficult to find any figures, which tells you something in itself). In a high-power application like a train it would lose a significant fraction of the energy, which affects charging time as well as efficiency. And there's no real need for inductive charging in an environment where contact charging is workable and the trains even carry the relevant equipment already.
