[BBC] New trains 'too heavy for tracks'
Mushroom
6 Mar 2006
Altrincham
New trains which have been introduced on several southern England routes have experienced track problems and rail delays because of their heavier weight.
The trains have been brought in by Southern, South West Trains, and Southeastern companies.
The Office of Rail Regulation (ORR) said the heavier trains were "causing a different sort of wear to the track".
Network Rail has blamed more track faults in part on "heavier trains with stiffer suspension".
Too many trains are being delayed and cancelled because of infrastructure problems that are the responsibility of NR
Bill Emery, Office of Rail Regulation chief executive
The trains have been brought in over the past two years.
A spokesperson from Network Rail said: "As part of the programme to allow new trains on the railway south of the Thames, Network Rail invested £440m on the Southern Power Upgrade scheme.
"The new trains are heavier and have stiffer suspensions than their predecessors so Network Rail - along with its stakeholders - is working to deliver a maintenance regime that is appropriate to the conditions."
He said Network Rail's new role in participating in the design of future trains would ensure that new trains would be even better designed, safer and lighter.
Although the number of temporary speed restrictions due to the condition of the track had fallen by the period prior to June this year, there was no decrease in South East England.
'Recipe for confusion'
An ORR spokesperson said: "Train companies will have to work out a different maintenance regime. The heavier trains are causing a different sort of wear to the track."
In its report, the ORR said it was concerned that the delays attributed to Network Rail had increased and that it was particularly concerned about one route in particular.
ORR chief executive Bill Emery said: "We are seriously concerned about Great Western and we have met with Network Rail to make sure they are fully aware of our concerns.
He said too many trains are being delayed and cancelled because of infrastructure problems.
Gerry Doherty, of the TSSA rail union, said: "This could only happen in Britain where we have such a fragmented rail network.
"Network Rail gets the blame for delays caused by trains that are owned by the banks and leased to the private rail operating companies. It is a recipe for confusion."
When asked if the problem could have been foreseen, Michael Lee, of the ORR, said: "It was predictable only up to a point. I don't think you could call this a mistake."
28 Jan 2007
A6-EHF
Ive just seen about it on BBC a NSE 465 was there:D , cant see how they make it heavier:?:.
4 words....
BRING BACK THE SLAMMERS.
David
9 Jul 2005
Scunthorpe
Most of the problems are the fault of the DafT who insisted on heave and robust designs, to prevent injuries in the event of an accident ....
TheSlash
7 Jun 2005
Marwell Zoo
Rolling Contact Fatigue.
It's crippling us on the Eastleigh section. We are having to change thousands of feet of rail at Ashurst to Totton, Southampton Airport to Swaythling, Millbrook, Fareham to Portchester, as it is cracking and needs to be changed before it gets to the point of a 20mph ESR.
5872
28 Jan 2007
A6-EHF
Ouch:(.
Dennis
8 Aug 2005
Trowbridge
Thought grinding was meant to sort out RCF
TheSlash
7 Jun 2005
Marwell Zoo
It just fire-fights it. It's not always easy to get hold of the Spino or the manual grinders
The good thing about the Spino is, when it's out, you get no other work done as you spend all night running round putting out fires 8)
raildog
31 Jul 2007
And we were just disussing how Double Deck coaches can significantly reduce the congestion problem!
With this state of affairs were a 375 is "heavy", then DD coaches I guess will never see light of day here.. Or is there a possibility? if Network rail does something about the tracks?
-RD
Meld
27 Apr 2007
Those that need to know - KNOW!!!
-RD
Intersesting thought about double deckers It has been done in the past the SR did have some 4DD units running from 1949-71 so it is possible to fit DDs in the loading gauge see http://en.wikipedia.org/wiki/British_Rail_Class_4DD for a little more info.
Getting back onto heavier trains I wonder if the track access charges are higher for a 375/7 as opposed to the slammers ;)
