BE coded Super Off Peak restrictions, not apply days and easing
cumfy
11 Sep 2011
When it says "This restriction code does not apply on the following dates/days:", does it mean the ticket is not available or that the restrictions associated with the ticket do not apply on the dates ?
Similarly what is the interpretation of the eased dates ?
Restriction Code: BE
SUPER OFF-PEAK
From Until Eased on these days:
Sat 2 Jan 2016 Thurs 24 Mar 2016 Su Sa
Fri 25 Mar 2016 Mon 28 Mar 2016 Su Mo Fr Sa
Tues 29 Mar 2016 Sun 1 May 2016 Su Sa
Mon 2 May 2016 Sun 8 May 2016 Su Mo Sa
Mon 9 May 2016 Sat 14 May 2016 Su Sa
From trainsplit.com
It means that the restrictions associated with the ticket don't apply on the dates listed.
It means the restriction is eased on the date ranges listed.
This is one case where it really does mean what it says. That said, the official text at NRE doesn't list the dates.
cumfy
11 Sep 2011
:o
So...
Do any routing restrictions still apply ?
And is there any difference between a restriction not applying and being eased ?
Originally I was just assuming the tickets simply weren't available weekdays, but an easement allowed them on certain weekends.
So...
Unless specifically listed on the restrictions page, then yes.
If you look at the NRE page for code BE the restriction doesn't apply on Saturday or Sunday. It is additionally eased on the dates that you listed in your post (they are weekdays so it should apply).
Haywain
3 Feb 2013
I may be misunderstanding what you have said, but what the OP has quoted means that the (time) restrictions do not apply on the specific days of the week stated for the date ranges given. So, for the date ranges given the restrictions do not apply on Saturdays, Sundays and public holidays. I believe that the information is written in this way for the benefit of booking engines.
furlong
28 Mar 2013
Reading
And if you believe that NRE page you can even use these tickets in the morning peak :oops:
Super Off Peak Day Travelcards are valid at any time where journeys are wholly within London Zones 1-6.
I may be misunderstanding what you have said...
Quite possibly, as I didn't write it as clearly as I could have. I was trying to explain the difference between days when the restrictions don't apply (weekends) and days when it is eased (the weekdays listed).
