mister-sparky
Hey guys, can a Berlin Zone ABC ticket be used on any train within the zones? ie an ICE or IC from Spandau to Hbf? Or is it just local trains? Thanks
not IC/ICE
Though I believe there are some exceptions to this as there are a very limited number of specific ICE/IC that can be used. Where such a list might be found however is beyond me but I've definitely seen reference to it!
Only RB/RE/IRE/S, not IC/ICE.
Yes, nowhere in Germany does DB accept Verkehrsverbund tickets on ICE, IC or EC trains apart from when there's a big chaos on the railway, with the only exceptions being the IC trains between Bremen and Norddeich Mole, and on the Gäubahn in Baden-Württemberg as well as the following trains in the VBB area: https://www.bahn.de/regional/view/regionen/berlin_brbg/info/vbb_ic_nutzung.shtmlReally? I've used it on a ICE between Potsdam and Berlin Hauptbahnhof with no issues - think it was a ICE 3 as you could see the same view as the driver.
Of course I probably was lucky at the time!
I was going to say that you have a very good chance of fare-dodging on intra-city local journeys on ICEs due to the lack of barriers and lack of time for on-board checks, a bit like Deansgate<->Picc in Manchester used to be effectively free prior to barriers there. But fare-dodging is what it is; Verbund tickets are only generally valid on RB/RE/S/IRE, though there are odd edge cases and upgrade tickets in some areas.
I didn't know that at the time
Which of course would have been no excuse if your ticket was checked! The Germans are very "zero tolerance" when it comes to invalid or (ticketless) travel!
They are, though they tend not to prosecute, it's just a fairly hefty Penalty Fare (EUR80/100 ish?)
I should have said though but I got forgot to say but I did have a valid ticket for that journey as I had both the ABC ticket and a rail ticket enabling me to use any DB service for a period of time so in any case if I was checked would they have any issue with me if I first presented the wrong ticket but then once I understood it wasn't valid actually showed them the valid ticket?
It's officially valid aboard (within ABC):
Berlin - Bernau
ICE: 1531, 1712, 1714
IC: 1924, 1970, 2422, 2424, 2426, 2428
Bernau - Berlin
ICE: 1713, 1729, 1736
IC: 1932, 2325, 2421, 2423, 2426, 2428
Potsdam - Berlin
IC: 1031, 2431
Berlin - Potsdam
IC: 1002, 2432
Is there a link to this? Would be interested in your source.
So would I as I am now very confused
VBB-Karten gelten auch in ausgewählten EC / IC Zügen
Bitte beachten Sie:
- VBB-Fahrkarten bitte im Vorverkauf lösen, da kein Verkauf in diesen Zügen möglich ist.
- Das Brandenburg-Berlin-Ticket / Brandenburg-Berlin Ticket Nacht wird akzeptiert.
- Schönes-Wochenende-Ticket, VBB-Kombi-Tickets (z.B. Veranstaltungskarten mit Fahrberechtigung) und Sonderfahrkarten gelten nicht.
- unentgeltliche Nutzung durch mobilitätseingeschränkte Reisende mit Schwerbehindertenausweis und gültiger Wertmarke bis zum letzten Haltebahnhof im VBB-Bereich
Abschnitt/Züge
Berlin - Bernau - Eberswalde - Angermünde - Prenzlau
Prenzlau - Angermünde - Eberswalde - Bernau - Berlin
Potsdam - Berlin - Lübben - Lübbenau - Cottbus
IC: 1031, 2431
Cottbus - Lübbenau - Lübben - Berlin - Potsdam
IC: 1002, 2432
