Best Driving route from London to Scotland?
Discussion in 'General Discussion' started by Samuel88, 10 Jul 2019.
  1. Samuel88
    Samuel88 On Moderation
    384
    20 Jan 2017
    I need to drive to Edinburgh tomorrow, I've never driven that distance before, so am quite apprehensive. Google is telling me to go via the M1/A1 but a friend advised me to travel via the M40/M6/M74/A702. Which way is the best for a nervous driver?
    Rail Forums
  3. telstarbox
    telstarbox Established Member
    4,530
    23 Jul 2010
    Wennington Crossovers
    Where are you starting in London? If you're east of the centre I'd go up the A12 and M11, then at Cambridge the road will lead you onto the A1 (signed THE NORTH).
  4. Geezertronic
    Geezertronic Established Member
    3,686
    14 Apr 2009
    Your route from the M40 would take you down the M42 then M5 to pick up the M6 however I would personally avoid that like the plague at the moment because of the roadworks on the M5 so would go M42 towards the Airport/NEC then pick up the M6 North there, or even better the M6 Toll just a bit further on from there (for a price of course).
    That is if you choose that way
  5. cactustwirly
    cactustwirly Established Member
    5,300
    10 Apr 2013
    All much of a muchness really.
    Personally from London I'd take the M1/M18/A1, the M40/M6 avoids roundabouts, but is quite a long route and there could be lots of traffic.
    The A1 has lots of roundabouts at the southern end and it is quite slow.
  6. telstarbox
    4,530
    23 Jul 2010
    Whichever way you go, I would keep Google Maps running as it will pick up any congestion and divert you accordingly.
    Good luck!
  7. Geezertronic
    3,686
    14 Apr 2009
    M40/M42/M5/M6 - once you start getting close to the M42 the traffic will be noticeable. If you carry on and join the M42 towards the M5 you hit the roadworks on the M5 North which are dire. If you go onto the M42 towards the Airport/NEC then you at least have a choice of sitting in traffic through Spaghetti or paying the money to go down the Toll
  8. bramling
    bramling Established Member
    7,247
    A1 every time for me. The London end is arsey at rush hour, but so is every route at that time. Otherwise it’s quite a pleasant drive, and the change in road type for various sections means it’s a less boring drive. Nowadays there’s zero roundabouts from Huntingdon to Berwick. The section through Tyneside can be a bit hairy, but much less so than the M6 around Birmingham.
    I’d avoid M1/M6 at the now as there’s masses of roadworks at the moment - around Northampton on the M1 which goes on for many miles, and at least one set on the M6 around Coventry-Birmingham, IIRC more further north too.
    If you do choose M6 I’d definitely pay to use the toll road, it really cuts out a lot of hassle.
  9. thejuggler
    thejuggler Member
    650
    8 Jan 2016
    The single carriageway section of the A1 north of Berwick is a royal PITA. I try and avoid it.
    Another option is A1, A66, M74 then cross country, but it does depend where in Edinburgh are going.
    Whichever way remember its circa 400 miles. If you have never driven that far before be mindful of how long it is taking and have regular breaks. At best its about 7 hours, but can get into double figures depending on traffic.
  10. PeterC
    PeterC Established Member
    2,348
    29 Sep 2014
    I can't comment on the A1 north of Scotch Corner but otherwise I agree about it being nicer to drive. You also still have a few proper transport cafes on the route. If you like a classic rock 'n' roll soundtrack with your coffee there are also a couple of OK Diners.
  11. bramling
    7,247
    Personally I’ve never found the Berwick section too bad. After dual carriageway all the way from London it’s a welcome change in some ways, the only risk is being stuck behind a caravan, but it’s still quite possible to get a decent run through that section even at busy times.
    I’ve done London to Berwick in about 4 hours 15 minutes, albeit very early on a Sunday morning. In the absence of the roadworks south of Darlington (which I believe are now finally finished) a little bit more could be knocked off this. During the day it will of course be quite a bit more.
    The A1 also offers more frequent stopping opportunities than motorways. Nene Valley Railway, Piercebridge Roman Fort and Holy Island are good places to stop off and take a break, or Barnsdale and Penmanshiel tunnels if that floats the boat!
  12. Struner
    Struner Member
    614
    13 Dec 2018
    Ommelanden, EU
    The A1 is of course partially dual carriageway, so you may get stuck behind a combine for a while :E
    & when you go by the A1, you can leave it at Newcastle to go by the Carter Bar. The A68 is a much grander way to enter Scotland. & I don't think there's much difference in time.
  13. Bald Rick
    Bald Rick Established Member
    10,823
    As others have said, it depends whereabouts in London you are starting.
    However (and as @bramling mentioned) there are a lot of roadworks on the M1 (about 20 miles from MK to Northampton) and M6 (about 12 miles from Coventry to the M6 toll, and 18 miles from Stafford to Stoke), plus the M6 from Stafford to Knutsford is always very busy unless you are travelling very early/late or overnight. The M6 doesn’t really get easy until Preston, but from there to Gretna it’s a pleasure to drive.
    I would go A1.
  14. DarloRich
    DarloRich Veteran Member
    23,335
    Work - Fenny Stratford(MK) Home - Darlington
    M1/M18/A1 although the m1 is always full of roadworks
  15. bramling
    7,247
    All these roadworks have made the M1/M6 route a complete pain in the arse at the moment. Recently I’ve taken to A1/A14 when heading to the north-west, although this doesn’t avoid the Coventry roadworks unfortunately. The A14 between Huntingdon and Rugby has proved surprisingly okay considering this road is quite notorious locally.
    Another pleasant route is M1 to Kegworth then A50 through Uttoxeter to Stoke, then join the M6 there. The M6 through Warrington is always bad, presumably as the Latchford viaduct is a bottleneck.
    I would *always* go A1 by default unless going to north wales or somewhere in the north-west south of Penrith.
  16. 30907
    30907 Established Member
    8,007
    The road out of Newcastle is the A696.
    The A68 actually leaves the A1 not far north of Scotch Corner, is only a few minutes slower than the A696, and a rather more interesting drive than the A1M. And cuts out the congested and narrow bit from the Angel of the North to Scotswood Bridge as well.
  17. Cowley
    Cowley Established Member
    7,143
    15 Apr 2016
    Devon
    Although I’ve taken all of the routes mentioned from London to Scotland, reading this thread reminds me of the choices of route between Exeter and London:
    M5/M4 - efficient, all motorway, and soulless.
    A30/A303/M3 - More direct, more roundabouts, more to think about, way way more interesting and romantic somehow, Stonehenge, scenery, exciting.
    The Old London Road.
    Just like the A1... I’d probably do the A1 because it’s an interesting route and it’s a bit more interesting.
  18. GusB
    GusB Established Member
    1,877
    Elginshire
    I've never driven south of the border, and I've no personal experience of any of the London-Scotland routes mentioned here, but last week I had my first motorway experience in over ten years when I had to drive to Edinburgh for a wedding. I hated it. I'd driven the same roads before as a younger, and probably more aggressive driver, but I just find the whole 70mph thing to be far too much these days. I'm happy to keep up with the traffic at 60mph on a single carriageway road, and if something slow gets in the way, that's just the way life is. On my return journey I ditched the motorway at Kinross and took smaller roads all the way back up north; the journey took almost twice as long than it would have done sticking to the main route, but I enjoyed the drive, and encountered far fewer a***h**** than I would have done on the trunk route.
    To the OP, my advice is to take whichever roads you're comfortable with, allow plenty of time for your journey and do take regular breaks to have some refreshment and stretch your legs a bit.
  19. 90019
    90019 Established Member
    6,613
    29 May 2008
    Edinburgh/Leeds
    Given the last sentence, I'd say the M1/A1 is the better option.
    The North section is easier than the A702 if you're unsure or nervous, in my opinion - the single carriageway sections of the A1 are more open and less twisty than the 702.
    Having done lots of journeys both ways on both roads, I'd definitely recommend the A1 as it's a much nicer road than the incredibly dull M6.
  20. Heinz57
    Heinz57 Member
    646
    4 Aug 2009
    Ilkeston
    I'd suggest M1-M18 and catch the A1 near Doncaster. There has been a few works on the M1 recently, but along your route you'll only find them near Northampton. They only go on for a few junctions and if you travel at the right time they aren't too bad.
    The A1 out of London through Stevenage towards Peterborough has a lot of single carriageways and islands and it's a bit tedious.
  21. Bald Rick
    10,823
    M1 roadworks is only 2 junctions... but it’s 20+ miles!
    There is no single carriageway on the A1 between the North Circular and Morpeth, and only 9 roundabouts in that distance; all of them south of Huntingdon (and 4 of those between Mill Hill and Borehamwood).
  22. Barn
    Barn Established Member
    1,422
    3 Sep 2008
    For confident drivers, once past Newcastle going North, how do the A1, A68 and A697 compare in terms of scenery and speed?
    If doing a return trip, which two of these options would you take?
  23. Struner
    Struner Member
    614
    13 Dec 2018
    Ommelanden, EU
    A68 by the Carter Bar #1!
    & there are quite a few ways to get to the A68. Have a good look at the OS 1:50k map.
    & when they are not messing about on the otterburn range (every other weekend), make your way back (as it seems you're based in England) from Byrness on the A68 to Rothbury.
  24. EssexGonzo
    EssexGonzo Member
    455
    9 May 2012
    Personal view - A1 all the way if you're not in a rush. If you're willing to pootle at between 60 and 70mph, it's actually quite relaxing. The 4-lane M1 - whilst quicker - would be more intimidating as lane discipline is terrible and it does get busier.
    TBH, you can't really go wrong with the A1 all the way. As others have said, there are plenty if scenic diversions and Google Maps will always get you back on track. But the A1 quite literally covers your entire route. There are LOADS of places to stop.
    Also as some have said, M11/A14 is a good starting route if you're on the east side of London.
    Have a good trip!
  25. Bletchleyite
    Bletchleyite Veteran Member
    46,727
    Up and down the south WCML (mostly)
    M6 has the super-scenic Shap, but I'd probably, if I wasn't in a hurry, choose the A1 for ease of driving.
  26. ian1944
    ian1944 Member
    285
    13 Dec 2012
    North Berwick
    If you choose the A1 to past Newcastle, slower but quieter and more scenic alternatives to keeping on that road are A697 to Wooler then B6525 back to the A1 south of Berwick, or A697 to Coldstream then A6112 to the A1 at Grantshouse, or A697 to Carfremill then A68.
  27. MonsooN
    MonsooN Member
    147
    30 Mar 2016
    Houghton le Spring
    In my (not inconsiderable) experience of driving north/south, I find it's better to stick to the M1 rather than going up the M18 and A1. It's approximately 7 miles further, but you will inevitably get held up for longer than 7 minutes at the A1/M18 junction and then further up the A1 around Doncaster and Selby. The M1 between Sheffield and Leeds, on the other hand, is usually pretty free flowing.
  28. DarloRich
    23,335
    the constant M1 route always seems longer which is why I use the M18. Plus it lets you avoid the Meadowhell, if only to trade for the delay at the M18/A1 junction!
  29. Puffing Devil
    Puffing Devil Established Member
    2,193
    11 Apr 2013
    I'd take this a stage further and just let Google decide on the route.
  30. DarloRich
    23,335
    that is why people drive into the river at Stanhope in Weardale.
  31. Puffing Devil
    2,193
    11 Apr 2013
    Would that be the closed ford that would not form part of a Google Maps route, but may have troubled some early satnav users who should, perhaps, not be out driving alone if they plunge their vehicle into an unsafe ford?
Share This Page
