Will definately look into it! Thanks
Yes i will deffinately buy one, thanks for the adviceIf you can afford, I would also suggest getting a UV filter to protect the front of the lens from the weather. It is a lot cheaper to replace a filter than the entire lens.
Don't waste your money on a filter - they only serve to degrade your images. Cleaning the front element of a lens isn't difficult.
+1
I use lens hoods over UV filters which don't scatter/degrade the light. The only filter I will use for railway photography is a polarizing one but bear in mind this will reduce the light by up to about 3 - 4 stops
