Previous re-signalling and track rationalisation was around 1972That is curious regards to Falconwood.
and the installation of a London-facing crossover at Bexleyheath with suitable DOO equipment (so that during future landslides services can get as far as Bexleyheath before returning) and a country-facing crossover at Eltham (so that during engineering works trains can get to Eltham for Bus connections to Crossrail etc in Woolwich).
What are london/country facing crossovers ? As to the DOO equipment, I though that there can't be any new installations of DOO monitors and any new DOO must be onboard CCTV ?
Barnehurst Platform 2 also turns back to London. You can go in either direction.
There's not a lot of point in installing redundancy in the London area, when there are two other (or three if you include Sole Street) diversionary routes available, and a plethora of frequent bus services linking them
You don't need any real dwell time to shut the train down. You can do it in less than a minute.
I will concede that your limitation is a single unit but this is easily overcome. If there was planned engineering works its even easier. This was done at Crayford last year and was done with 8 cars so the limit on a single unit was overcome with little effort.
Turning trains back takes longer than 5 minutes if your more than a 4 car.
I don't think it's cost effective to install a turnback of any sort between Bexleyheath and Barnehurst just for the sake of extending the turnback facility by 1 station. As I've mentioned previously, just fix the bloody bank. Adding a crossover is not a solution as disruption can happen anywhere along the route. If you want end to end turnbacks then Barnehurst/Lewisham would be the most effective.
Why choose Eltham and leave Kidbrooke unserved ? There used to be points at Kidbrooke so there is precedent for them to be reinstalled.
4 car trains turning round at peak times? Offering a 4 car peak service?
Said trains not able to get to Barnehurst because of the landslides?
Are you mad?
Where have I said about running 4 Car trains in the peak ? Potentially some confusion here. To clarify; you stated it would take less than 5 minutes to turnaround during planned engineering works. Turnaround times on units/train lengths longer than 4 cars are greater than 5 minutes
So there are landslips at Barnehurst so you want on spend thousands on putting in points "just in case" Why chose to install points and not tackle to problem of the bank slipping ?
What happens when we install these crossovers and turnbacks but there is a problem at Welling ? Do we then demand a crossover at Falconwood ?
For what ? Suggesting we fix the bank rather than install a crossover ?
During disruption I've been over the Sidcup & Crayford crossovers and also wrong line/direction moves between Sidcup & Crayford. The NorthKent controlled Signalling seems to allow it, albeit with no intermediate signals. Only once, during a embankment slip, been over the Lee one and that required SLW with Pilot person. Hopefully when Hither Green area gets re-controlled to Three Bridges ROC they can make the Lee one more usable, as I can see it being quite useful to have a turn back capability at Hither Green.Sidcup line has them at Lee and Sidcup and the Woolwich line has them at Charlton and Plumstead.
Why did it require SLW ? Or did you use SLW between Lee and Crayford ?
What difference with re-controlling it to TBROC make ?
You can turnback at Hither Green already.
Cheers in advance
but not realistically from HG - Dartford as finding a pilot etc would be difficult.
Having spoken to an NR source, in order to do the bank work will require around 3 months (at least) or intrusive interventions closing the line. They would therefore need a crossover anyway as part of the works which you may as well install immediately for use during service perturbation etc before you can find the much bigger funding needed for the bank work.
Two crossovers will cost at least £5m.
How much work is involved in installation of a crossover ? I'm thinking more on the line of the main physical grunt work of digging up the track and laying track. I'm sure I've seen weekend engineering works renew junctions in a couple of days. Granted that is just track work and a new installation would require signalling etc but when Network Rail make an effort I have seen some really impressive work in a short amount of time.
Thanks as always.
Will the new crossover finally allow freight to leave Angerstein in both directions?Thanks.
Charlton is undergoing new signalling and a new crossover getting installed. For months I have watched the slow but incremental installation and I fully expect a single weekend to install the points and then on the Monday morning drive it like its been there forever. FYI You can add in Driver briefings to the prep work.
Compare and contrast to what's happening at Orpington, with what looks like track realignment, reduction in speed and a fair bit of track renewal work.
Kudos to the Orange Army.
So no use for freight then?The crossover will take you into the up platform from Angerstein/Blackheath side.
