Biggleswade to City Airport - via HS1?
stut
25 Jun 2008
Sorry for yet another HS1 fare thread...
Am utterly confused by the range of tickets to get me where I'm going. The route from Biggleswade to City Airport via Stratford Int is easily the quickest when the through DLRs are running, but I can't figure out the best way to buy it.
The obvious seems to be to get BIW-SFA single, then Oyster it from there. But that's quite expensive. The East Coast site reckons a single to SRA is valid via HS1, but is that correct? Can I buy a ticket via WWA and claim to use HS1 and DLR as a valid route, breaking my journey at City Airport?
This will be peak times in both directions.
Please help a bemused commuter...
(FWIW I don't have a season ticket, as my travel patterns are irregular...)
MCR247
7 Nov 2008
Via Stratford Intl is easily quickest?! Not disputing it, but it didn't occur to me as the quickest route!
I take it you are travelling during the peak since Stratford Intl trains only go to Beckton off peak with a service frequency of every 10 minutes, so quite a long wait if you miss one!
stut
25 Jun 2008
Yup, travelling in the peak. Speed depends on connections, really, but the other options have a habit of being a bit of a pain with luggage, which tips the balance in the favour of Stratford Int. Effectively, though, arriving at KGX 9-11 puts you closer to the HS1 platforms than the Northern Line!
benk1342
13 Jul 2011
Welwyn Garden City
Given that the Biggleswade – Stratford International (route "London Not Underground") fare is set by Southeastern I think it must be valid on HS1.
Also valid per the routing guide---routing points are Hitchin and Stratford London Group, route is London, London to Stratford London Group is valid via map HS.
I don't think this would work. The routing points for Woolwich Arsenal are Charleton and Slade Green (both pass fares check). Routes from Hitchin to either of these are via London. But the only permitted routes from London to Charleton/Slade Green are via maps CT and NK. Both require you to go out of London Bridge.
Right? Someone with more routing experience please correct me if I'm wrong.
34D
9 Feb 2011
Can't add anything to the question, except to observe that your chosen route seems very sensible (esp with luggage) and it is a shame that HS1 isn't properly integrated to the fares system (ditto heathrow express) otherwise these issues would be catered for.
MikeWh
15 Jun 2010
Crayford
The DLR bit is all one zone so only £1.50 peak on Oyster.
Given that you feel the fare is expensive I'd say yes. Plus I agree with other claims above too.
No, that wouldn't be valid unfortunately.
bb21
Emeritus Moderator
4 Feb 2010
Am I missing something here? The Route +Any Permitted fare to SRA and SFA appear to be exactly the same so you're not really saving anything by buying the SRA fare.
There is no need to buy a Route London Not Underground ticket.
stut
25 Jun 2008
I can't see a BIW-SFA +Any Permitted when I search - only Via Hackney Wick and London Not Und. Checked the Biggleswade ticket machines on the way home too, out of idle curiosity. Am I looking in the wrong place.
I know there's not much in it, but I never like paying more than I need to!
bb21
Emeritus Moderator
4 Feb 2010
The +Any Permitted routeing appears in the Manual (where there seems to be three different routeings, including the two you mentioned). It is a possibility that there is some sort of discrepancy.
stut
25 Jun 2008
A discrepancy, you say :) Oh well. As the company is paying, I suspect I'll end up stumping up for the full fare, as I'm not exactly going to have time on my side on Monday morning.
Thanks to all for your help and input.
Ivo
8 Jan 2010
Bath (or Southend)
NFM 11 suggests that the +Any Permitted fare is valid into SRA, but not SFA. The London Not Und fare seems to be the reverse.
benk1342
13 Jul 2011
Welwyn Garden City
Yes, but both Stratford Int'l and Stratford use routing point Stratford London Group, and a permitted route from Hitchin (Biggleswade's relevant routing point) to Stratford London Group is Hitchin to London (King's Cross) via map EE, then London (St Pancras) to Stratford via map HS. So regardless of whether you buy the ticket to Stratford (route +any permitted) or Stratford Int'l (route London Not Und) you can take HS1. So you may as well buy the cheaper one.
