Birmingham - Banbury - Heyford via Oxford?
class175
18 Aug 2010
Oxfordshire
Hi All
So I recall hearing that one can double back on certain routes a long time ago, and wondered if the route mentioned (Birmingham New St - Banbury - Heyford) is valid if we went and did a Break of Journey at OXF (where we actually want to go), or have those loop-holes been closed now?
Cheers
-M
bb21
Emeritus Moderator
4 Feb 2010
This is not permitted from what I can see.
Starmill
Fares Advisor
18 May 2012
Bolton
There are probably more legitimate ways to reduce the cost of Birmingham to Oxford journeys. Check out trainsplit, and it might help you to consider traveling with a Chiltern only ticket between Birmingham and Banbury if you can use them.
kieron
22 Mar 2012
Connah's Quay
One common way for a double back like that to be available is for (in this case) Heyford to be a station associated with Oxford (something you can check on the list here), and for the cost of a a Birmingham-Heyford single to have been higher than an equivalent Birmingham-Oxford one in 1996.
You can check this on farehistory.info, and ATOC (the rail industry's trade body) has a page here which they promote as providing an equivalent calculation.
It doesn't say that Birmingham-Heyford via Oxford is valid, but it's there for if there are any other tickets you're wondering about.
