Birmingham New St to Alfreton Sat 25th July
Discussion in 'Fares Advice & Policy' started by shuggie61, 11 Mar 2009.
Thread Status:
  1. shuggie61
    shuggie61 Member
    43
    3 Mar 2009
    I'm travelling from Birmingham New St to Alfreton for the Indietracks Festival nr Alfreton. It's at the Butterly Railway Museum on Sat 25th July.
    Travelling to arrive at about 3-00 pm
    Leaving after 6-00pm
    No railcard.
    No flexibility cos I'm singing at 4-30! Ta.
    Rail Forums
  3. Mcr Warrior
    Mcr Warrior Member
    794
    8 Jan 2009
    :? Don't think that any advance tickets (for all or part of the route) are available yet, as it's more than 12 weeks until 25th July, but if you are going there and back on the same day and want some flexibility on what trains you catch, then an Off Peak Day Return ticket from Birmingham New Street to Nottingham is available at £13-20, and then you'll need an onward Off Peak Day Return ticket from Nottingham to Alfreton which will cost another £7-40. Total £20-60.
    Or you could get an Off Peak Day Return from Birmingham New Street to Derby, cost = £11-70, and then a Derbyshire Wayfarer at £8-30, which would be valid from Derby to Alfreton via Chesterfield. Total £20-00.
    Alternatively, a through off peak return ticket from Birmingham New Street to Alfreton would cost you £28-00, but would give you the additional flexibility of being able to travel both via Chesterfield and/or Nottingham.
  4. OwlMan
    OwlMan Established Member
    3,204
    25 Jun 2008
    Bedworth, Warwickshire
    The quickest route is to go by train to Drby and then bus to Butterley - it is not worth getting to Alfreton by train as you will still need to catch a bus from there and to get there at the same time as the journey below you would need to start an hour earlier and it would cost you quite a bit more
    Route Information
    Start from BIRMINGHAM NEW STREET Station
    Take the Cross Country Trains train going to ABERDEEN Station Depart 13:03
    Alight at DERBY Station Arrive 13:41
    Transfer to Derby: Corporation Street Stop J2
    Take service 9.1 operated by Trent Barton Depart 14:15
    Low floor easy access bus normally provided
    Finish at Ripley: Butterley adj Midland Railway 14:48
    Take the Cross Country Trains train going to NOTTINGHAM Station Depart 12:19
    Alight at NOTTINGHAM Station Arrive 13:36
    Take the East Midlands train going to LIVERPOOL LIME STREET Station Depart 13:45
    Alight at ALFRETON Station Arrive 14:06
    Transfer to Alfreton: Mansfield Road opp Rail Station
    Take service 9.3 operated by Trent Barton Depart 14:23
    Alight at Ripley: Butterley opp Midland Railway Est Arr 14:51
    Transfer to Ripley: Butterley adj Midland Railway
    Start from Ripley: Butterley adj Midland Railway
    Transfer to Ripley: Butterley opp Midland Railway
    Take service 9.2 operated by Trent Barton Est Dep 18:36
    Alight at Derby: Corporation Street Stop J2 Arrive 19:10
    Transfer to DERBY Station
    Take the Cross Country Trains train going to GUILDFORD Station Depart 19:53
    Finish at BIRMINGHAM NEW STREET Station Arrive 20:27
    Buy an offpeak day return from Birmingham - Derby
  5. gordonthemoron
    gordonthemoron Established Member
    5,899
    4 Sep 2006
    Milton Keynes
    I don't know if two singles would be cheaper, but the Trent Barton ZigZag day ticket is valid for your bus journeys and costs just £4.60
  6. John @ home
    John @ home Established Member Fares Advisor
    5,124
    1 Mar 2008
    I think you should use a Derbyshire Wayfarer. This is a day rover ticket allowing virtually unlimited bus and train travel throughout Derbyshire. An Adult Derbyshire Wayfarer costs £8.30 and is a scratch-off card available by post from the Public Transport Unit, Derbyshire County Council, County Hall, Matlock DE4 3AG.
    For your journey, this ticket is valid by train between Burton-on-Trent and Alfreton via Chesterfield. If you prefer to travel via Nottingham, there is a more expensive Wayfarer at £10.70 sold at Nottingham station and valid from there, but it is not clear from the wording on http://www.derbyshire.gov.uk/transp...rover_tickets/derbyshire_wayfarer/default.asp whether that ticket can be bought by post in advance. I would recommend the cheaper ticket via Chesterfield for you.
    From Alfreton, the Wayfarer ticket is also valid on buses 9.1, 9.2, 9.3 and 140 which run between Alfreton railway station and the Midland Railway Centre near Butterly.
    You also need an Off Peak Day Return between Birmingham and Burton-on-Trent which costs £8.70. That gives a total cost of £17.
    For this combination of tickets, you must choose trains which stop at Burton-on-Trent. If this restriction is inconvenient, you could buy an Off Peak Day Return between Birmingham and Derby at £11.70 instead. All relevant trains stop at Derby, so this combination lets you travel on any train via Chesterfield at an additional cost of £3, total £20.
    John
  7. gordonthemoron
    5,899
    4 Sep 2006
    Milton Keynes
    £11.70 plus £4.60 for a ZigZag ticket (bought on the bus) is only £16.30
  8. Mcr Warrior
    Mcr Warrior Member
    794
    8 Jan 2009
    :roll: Even cheaper would be just to buy a rail ticket from Birmingham New Street to/from Burton on Trent (£8-70) and then purchase/use a Zig-Zag ticket from there onwards (£4-60); however isn't this meant to be a Rail forum?
  9. gordonthemoron
    5,899
    4 Sep 2006
    Milton Keynes
    But then you'd have to get a bus from Burton to Derby, I don't think all trains stop at Burton & it takes longer from Burton to Derby than by train (although it is quite a long walk from Derby railway station to the bus station/stop)
  10. OwlMan
    3,204
    25 Jun 2008
    But it is difficult to get toi Butterley without using a bus.
    It is quicker to get a bus from Derby than travel to Alfreton and get a bus.
    Peter
  11. shuggie61
    shuggie61 Member
    43
    3 Mar 2009
    Thank you Mcr Warrior,colly bs,gordonthemoron,John@home for your help! Thoroughly comprehensive and useful! Ta all.
Thread Status:
Share This Page
