Blackfriars - London Bridge, Missing Oyster OSI link?
hkstudent
11 Nov 2018
SE London
It seems that Thameslink trains don't call at London Bridge after 2300, which London Bridge will still have trains to run till 0030. According to National Rail Journey Planner, there is a valid walking connection between London Bridge and Blackfriars for late trains (particularly for Luton / Gatwick / East Croydon)
However, there seems to be not having an OSI link for that, particularly there are no direct London Underground connection between the stations, and the District / Circle Line doesn't run to the late hours. Would the TfL need to add the link to fulfil a journey?
Last trains 2337 to Brighton / 2331 to Peterborough / 2335 to Bedford.
I wonder whether you could ask the barrier staff nicely if you can leave London Bridge without touching out and enter Blackfriars without touching in. Blackfriars barriers tend not to be staffed in the late evening, London Bridge barriers do tend to be staffed first to last train.
Or to get something official done, enter into correspondence with TfL.
I think going north the would expect people to use the Northern Line, which could be one explanation.
Yes, but there is an higher fare to pay if you go 'mixed-mode' and travel NR / LU rather than NR only on Oyster / Contactless.
The OP is seeking to avoid this.
People using paper tickets or who have already hit fare caps would clearly use the Northern Line.
Failed Unit
26 Jan 2009
Central Belt
Surely then the solution is use a paper ticket? I understand that when contactless comes to my local station I must be careful and continue using paper tickets for certain journeys to save money.
Jona26
2 Jan 2013
West Sussex
The City branch of the Northern Line does not have a night tube service though so wouldn't solve the problem for some late services potentially.
hkstudent
11 Nov 2018
SE London
Yes. Another issue is, there is no direct tube connetion from London Bridge to Blackfrairs. You need to get to Bank/Monument and change District/Circle Line there.
That shouldn't be the case if the journey is wholly within zone 1-6, particularly TfL calimed Oystercard be the cheapest mena of travel in London.
