It will be interesting how they tackle the raised platform issue at Bletchley. Simply because it is obstructed by a cement type factory and there are roads underneath the southern part of the station.
As a rail enthusiast for video and photography I believe the structure will obstruct any great viewing angles. At best we can hope for a Nuneaton style approach. Its also strange that it took 50+ years to get any great use of the flyover. I believe it gets approximately 1 train a month at present (or less) for rail testing purposes. I assume the track will be replaced.
Does anyone know if the flyover has a weight restriction? I believe it was designed with freight in mind so probably not.
Yes lets make sure station design takes into account the photographic needs of spotters :roll:
I am sure the concept drawings i have seen envisage a single platform on the fly over. The idea is that the stone terminal will be relocated ( aka closed!) but there are no firm dates for any of that! The council are keen on a station entrance on that side of the station giving much better connections to Bletchley town centre but lack the money to pay for it so that wont happen either!
As The Planner says there is "some" work to do on the concept!
The flyover was well used when trains used to run from Aylesbury to Bletchely depot and when the stone trains ran from Oxford to Wolverton but they ended some years ago. There has been the problem of a gap of several miles in the track for the last few tears
The line isn't used monthly at all. NR test trains run every so often but to no real pattern and the Swanbourne siding is used to stable engineering trains from time to time.
Interesting to read there's some interest in updates on this. For a number of days last week I saw a number of Network Rail and "UK Rail: Electrification" (?) branded vehicles parked at the Launton level crossing. And today I saw a number of Network Rail vehicles headed towards the location of the old Marsh Gibbon and Poundon Station - a little further along the line. I also think I am correct in saying that there has - in the past few months - been some vegetation clearance along the disused section between Claydon and Winslow.
There has been some veg clearance along the route to help with scoping and surveys etc
