Boardmasters specials to Newquay
Discussion in 'Allocations, Diagrams & Timetables' started by SWTrainspottin, 1 Aug 2018.
  1. SWTrainspottin
    SWTrainspottin Member
    353
    6 Sep 2016
    Newquay's annual Boardmasters music festival returns next week between 8 August and 12 August, which will see a lot of alterations to the services to Newquay on the few days. These services are pre-book only because they will be extremely busy. If you look on RTT, there will be a note stating that reservations are compulsory.
    Special STP services for the event operate on 8 August, 9 August, 10 August and 13 August. All except for ones in the WTT will have extra dwell time of up to 30 minutes at Plymouth and Exeter in each direction and will call at (in each direction) Par, Plymouth, Exeter and Reading.
    Local shacks (Luxulyan, Bugle, Roche, St Columb Road and Quintrell Downs) between Par and Newquay will be served by bus as well as receive a limited WTT service as explained below.
    8 August & 9 August
    2N02 0524 Bristol Temple Meads - Newquay 1009 (WTT)
    2N03 1013 Newquay - Par 1102 (WTT)
    1Z30 0649 London Paddington - Newquay 1209
    5C92 1234 Newquay - London Paddington 1738
    1Z31 0903 London Paddington - Newquay 1425
    1A96 1507 Newquay - London Paddington 2036 (WTT)
    1Z32 1118 London Paddington - Newquay 1710
    5Z58 1729 Newquay - St Phillips Marsh TMD 2131
    1Z33 1336 London Paddington - Newquay 1953
    5Z53 2003 Newquay - St Phillips Marsh TMD 0013
    2N12 2028 Par - Newquay 2120 (WTT)
    2N13 2126 Newquay - Par 2215 (WTT)
    10 August
    2N08 1610 Par - Newquay (WTT)
    2N09 1722 Newquay - Par (WTT)
    2N10 1829 Par - Newquay (WTT)
    2N11 1924 Newquay - Par (WTT)
    11 August
    Saturday's WTT as normal.
    12 August
    Sunday's WTT as normal.
    13 August
    5Z40 0452 Laira TMD - Newquay 0655
    1Z40 0732 Newquay - London Paddington 1306
    2Z41 0748 Par - Newquay 0843
    1Z41 0923 Newquay - London Paddington 1507
    5Z42 0830 Laira TMD - Newquay 1033
    1Z42 1055 Newquay - London Paddington 1621
    2Z43 1027 Plymouth - Newquay 1204
    1Z43 1242 Newquay - London Paddington 1820
    1C74 0903 London Paddington - Newquay 1418 (WTT)
    1Z44 1507 Newquay - London Paddington 2036
    5Z45 1117 London Paddington - Newquay 1643
    1Z45 1703 Newquay - London Paddington 2239
    5Z46 1655 Plymouth - Newquay 1841
    1Z46 1855 Newquay - London Paddington 0001
    Rail Forums
  3. SWTrainspottin
    353
    6 Sep 2016
    Car-park at Newquay station shut off for the week to be used as a queuing system.
    Will try and keep real time updates on this thread with the services over the next few days. Also to mention there is currently no path for 1Z32 1118 London Paddington - Newquay on Thurday 9th however this is definitely booked to run on this day (as well as Wednesday 8 as mentioned).
  4. SWTrainspottin
    353
    6 Sep 2016
    43154 - 43041 just worked 1Z30. Will now work 5C92 to form 1C92 1803 London Paddington - Penzance.
  5. SWTrainspottin
    353
    6 Sep 2016
    8 August
    1Z30 / 5C92 worked by 43154 - 43041. 5C92 originally booked to work 1C92 to Penzance but owing to a track circuit failure near Castle Cary, it formed 5C93 out of Pad instead.
    1Z31 / 1A96 worked by 43171 - 43042. 1A96 diverted via Bristol owing to the track circuit failure at Cary.
    1Z32 / 5Z58 worked by 43017 - 43004.
    1Z33 / 5Z53 worked by 43190 - 43172. Was heavily delayed at Cary owing to the track circuit failure and ended up 93L at Taunton. Eventually 80L at Exeter and 39L at Plymouth due to its dwell time before arriving Newquay 26L. Short turn-round time meant that 5Z53 to St Phillips Marsh left 25L, delaying 2N12 at Goonbarrow.
    2N03 / 2N03 and 2N12 / 2N13 worked by 150261. Between workings, it was stabled in Par Liner Siding before working to Penzance and back (which would usually originate at Newquay). 2N12: 19L at Goonbarrow owing to the late running of 5Z53 before arriving Newquay 15L. Return was 10L at Newquay and 6L at Par.
    Exact same workings today until Friday where two of the additional services run instead of four.
  6. SWTrainspottin
    353
    6 Sep 2016
    Some changes to next Monday's timetable. 5Z42 ECS to Newquay now to start at Exeter instead of Plymouth. 1Z43 will now be formed off of 2Z43, which is in service but still express (calling at Par along the way only).
  7. dk1
    dk1 Established Member
    6,215
    2 Oct 2009
    East Anglia
    Plenty of sniffer dogs awaiting the arrivals at Newquay too. Was like an early Christmas for them :lol::lol:
  8. D1009
    D1009 Established Member
    3,166
    22 Feb 2012
    Stoke Gifford
    I find it amazing GWR is able to cover the event on this scale given the recent difficulties it has had with rolling stock and driver shortages. What other TOC is able to run so many extra trains over a 300 mile route?
  9. SWTrainspottin
    353
    6 Sep 2016
    With more 800s coming into service, there have been enough to cover enough HST work I guess. 800s have been covering a lot more work because of these HSTs being used for Boardmasters.
  10. 4141
    4141 Member
    102
    21 Dec 2015
    Plus with Boardmasters being a known big event they've had plenty of time to work up paths and rosters?
  11. D1009
    3,166
    22 Feb 2012
    Stoke Gifford
    Yes, with a few short formations I notice. However with some exceptions you can probably get away with that mid week at this time of year.
  12. SWTrainspottin
    353
    6 Sep 2016
    9 August
    1Z30 / 5C92 worked by 43017 - 43004. 5C92 caped at Newton Abbot with the set then being swapped to work 1A90 1454 Paignton - London Paddington from Newton Abbot onwards. Reason for this being that 1C77 to Paignton failed and arrived Newton Abbot 44L. Set was taken out of service and went 5C77 to Laira.
    1Z31 / 1A96 worked by 43129 - 43197. 1A96 diverted via Bristol once again (same happened yesterday). I'm not too sure why.
    1Z32 / 5Z58 worked by 43137 - 43176.
    1Z33 / 5Z53 worked by 43155 - 43136. 5Z53 last reported at Whiteball at 2311, running 10L.
    2N02 / 2N03 and 2N12 / 2N13 worked by 150266.
    Tomorrow, two of the four specials run. From then the timetable is WTT until Monday.
  13. D1009
    3,166
    22 Feb 2012
    Stoke Gifford
    I believe there is a P Way issue somewhere between Cogload and Castle Cary.
  14. PHILIPE
    PHILIPE Established Member
    9,321
    14 Nov 2011
    Caerphilly
    Up Line has been closed for 2/3 days and trains diverted via Bristol but seems to be merely a speed restriction this morning.
  15. SWTrainspottin
    353
    6 Sep 2016
    10 August
    1Z30 / 5C92 worked by 43188 - 43131. 5C92 caped from Newquay with the set instead working 1Z92 (in service) to Plymouth, calling at Par and Plymouth. 5C92 then restarted at Plymouth with the same set and arrived London Paddington 21L.
    1Z31 / 1A96 worked by 43009 - 43159.
    2N02 / 2N03, 2N08 / 2N09, 2N10 / 2N11 and 2N12 / 2N13 worked by 150233.
  16. D1009
    3,166
    22 Feb 2012
    Stoke Gifford
    I get the impression that while people using the intermediate stations/halts on the branch are well catered for by RRBs, "ordinary" passengers to and from Newquay have been somewhat neglected, particularly on Monday.
  17. SWTrainspottin
    353
    6 Sep 2016
    I'm a local to Newquay so this effects me so I see what you mean. I'm using today to travel as it's all the Sunday WTT.
  18. SWTrainspottin
    353
    6 Sep 2016
    Been more changes it seems and these are Monday's workings.
  19. Cowley
    Cowley Established Member
    5,407
    15 Apr 2016
    Devon
    One of our boys is at the festival (his first ever) and wishes he could escape now but his ticket’s only valid tomorrow.
    Nothing like a soggy weekend in a damp tent to put you off this kind of thing.
  20. SWTrainspottin
    353
    6 Sep 2016
    13 August (Sorry its late)
    5Z40 / 1Z40 worked by? 1Z40 ran 7E early from Par and arrived Plymouth 9E. Was RT until Heywood Road Junction where it passed 26L and was diverted via Melksham. Departed Reading 27L and arrived Paddington 46L.
    2Z41 / 1Z41 worked by 43196 - 43133. 2Z41 was formed from 3Z41 0330 St Phillips Marsh TMD - Newquay but was caped between SPM and PLY. 3Z41 departed Plymouth 14L and arrived Par 25L. This resulted in a delay to 2Z41, which departed Par 23L and arrived Newquay 17L.
    5Z42 / 1Z42 worked by 43042 - 43170.
    2Z43 / 1Z43 worked by 43098 - 43010.
    1C74 / 1Z44 worked by 43070 - 43056. 1C74 departed Pad 19L and continued losing time throughout journey. Departed Plymouth 29L, Saltash 35L and Par 34L before arriving at Newquay 30L.
    5Z45 / 1Z45 worked by 43151 - ?. 5Z45 departed Exeter 22L but arrived Newquay RT. 1Z45 arrived Pad 17L.
    5Z46 / 1Z46 worked by 43022 - 43029. 1Z46 caped at Taunton due to a depot operating problem and formed 5Z46 2203 Taunton - Laira TMD.
    2N12 / 2N13 worked by 150239. In between workings, it was stabled in Par Liner Siding. 2C42 was 2Z42 instead and worked to Penzance. Then worked 2Z87 to Plymouth and returned with 2C46 which would usually start at Newquay. Unit then worked 2P92 to Par as usual and went to Liner Siding befoe working 2N12.
Share This Page
