Bolton Line 95/100mph Speed Increase
Discussion in 'Infrastructure & Stations' started by td97, 17 Jun 2019.
  1. td97
    td97 Member
    532
    26 Jul 2017
    As expected, it seems that the 95mph down/100mph up speed increases are live as of this week (17/06/19)
    Hit 91mph on an up train this morning.
    For context, there previously had been blanket 75mph.
    See attached graphic, think the unit was 319372. From Bolton to Salford Crescent. Think the GPS dropped out through Farnworth Tunnel.
    Rail Forums
  3. 47421
    47421 Member
    430
    7 Feb 2012
    london
    Is that an app you get that readout from? Which one?
    Anyone recommend an Iphone app that does something similar? Thanks
  4. td97
    td97 Member
    532
    26 Jul 2017
  5. hexagon789
    hexagon789 Established Member
    6,282
    2 Sep 2016
    Are there any plans to tighten sectional timings as a result?
  6. driver9000
    driver9000 Established Member
    3,691
    13 Jan 2008
    100mph running went live on 19 May 2019 and apart from TPE catching up with late running Northern stopping services it is working really well.
  7. hexagon789
    6,282
    2 Sep 2016
    Good to hear, another project which has successfully made a difference.
  8. td97
    td97 Member
    532
    26 Jul 2017
    There should be as the speed enhancements are a requirement for TPE to reinstate Bolton calls so they keep their Castlefield/WCML paths at either end.
    Really? I know there were some contradicting reports in the electrification thread and previous journeys I made seemed to max out at 75mph. Do Northern drivers not always reach the higher speed as it is not presently required for timekeeping?
    Have any Northern drivers hit the magic 3 figure number on a 319?
  9. hexagon789
    6,282
    2 Sep 2016
    So they might not extend the overall time but use the increase in permissible speed to cover for a Bolton call.
  10. driver9000
    3,691
    13 Jan 2008
    Yes. The ESR came off before the service started that morning (19 May). I have no idea if Northern Drivers are holding back or what speeds they have achieved on the line I'm afraid.
  11. Joseph_Locke
    Joseph_Locke Established Member
    1,806
    14 Apr 2012
    All of Northern's are still on diesel SRTs so there's no point hooning off, just to wait time. Even with a slack on at Clifton and 2 late off Bolton we still arrive at Crescent 1 early ... my GPS has never clocked one doing more than 82.
  12. superkev
    superkev Established Member
    1,606
    1 Mar 2015
    west yorkshire
    Pity they couldn't increase the Preston Blackpool bit which I believe is 60-70mph.
  13. hexagon789
    6,282
    2 Sep 2016
    Yes, seems to still be 75 to Kirkham & Wesham and 70 max beyond there.
  14. Ianno87
    Ianno87 Established Member
    5,230
    3 May 2015
    The higher speeds were definitely live on late May Bank Holiday Monday - 'felt' like about 90 on the Up through Farnworth (faster than usual), followed by definite braking for a 75 Temporary Speed Restriction just south of Kearslwy.
  15. Jozhua
    Jozhua Member
    611
    6 Jan 2019
    I tracked my 319 going direct from Bolton to Salford Crescent without stopping and it didn't seem to hit more than around 80mph, even then we were a bit early so there was probably no reason to go fast.
    Definitely slowed down to around 30 near the end probably to wait for a slot into Salford Crescent.
  16. coxxy
    coxxy Member
    220
    16 Aug 2013
    Probably people not ragging it to get up to 100mph.. will be easily achievable between Bolton and Salford Crescent.
    Since being resignalled you could get to Salford Crescent 4 minutes early in a 142 at a max of 75mph. Most people pretty much used to shut off at Kearsley due to the falling gradient and the train would easily be doing 75mph on the way down.
    I would suspect people are probably just rolling the majority of the way down the hill from Bolton so as not to get to Crescent stupidly early.
  17. ComUtoR
    ComUtoR Established Member
    5,856
    13 Dec 2013
    When I drove them (when they were down south) You needed a long run up, the wind behind you, a down hill gradient, on a sunny day in June, with your mates pushing, and a quick prayer to Jebus before it even pushed 90
  18. hexagon789
    6,282
    2 Sep 2016
    I thought they, like 321s, did 0-100 in 3 mins?
  19. Jozhua
    Jozhua Member
    611
    6 Jan 2019
    I believe they are only powered from one coach, which also has to accommodate passengers which may effect how much electronics can turn electricity into speed.
  20. hexagon789
    6,282
    2 Sep 2016
    They do have only one motor coach, but if it's dry enough that coach should be able to put down its 1,438hp easily enough. And certainly the less powerful (though also a bit lighter) 317s are, according to Angel Trains, capable of attaining 100mph in 3 mins.
  21. ComUtoR
    5,856
    13 Dec 2013
    Officially ? Not a clue.
    We used to run fast from St Albans and you almost got to Elstree before you hit 100 and you really had to keep it open (It's also downhill). Even then it was touch and go. Getting them to 100 was difficult.
    The second it rained...
    I loved driving them but they weren't known for their speed. They were good in the middle bit but just dropped off past 70 and then struggled. From what I've learned from this forum. It's down to how they are geared towards metro, so they are really nice at acceleration but bugger all else.
  22. hexagon789
    6,282
    2 Sep 2016
    Sounds like a lot of trains - good in the middle! :lol:
  23. themiller
    themiller Member
    581
    4 Dec 2011
    Cumbria, UK
    You can get a speed reading on NAVMII which is one of the apps that doesn’t use your data allowance as you download the maps beforehand and it’s free.
  24. Clip
    Clip On Moderation
    10,393
    28 Jun 2010
    Well depends on how you look at it because this service http://www.realtimetrains.co.uk/train/Y69130/2019/06/19/advanced has had its journey time increased by 10 minutes with a nice wait at Buckshaw and a nice wait at the signal just up from the station.
    So if making some journeys slower is a success then double gins all round
  25. hexagon789
    6,282
    2 Sep 2016
    Well I referring purely to the linespeed increases, though surely the point in them is to reduce journey times even if it's not at the present.
  26. Clip
    Clip On Moderation
    10,393
    28 Jun 2010
    of course the point is to reduce journey times but if they have increased them on some journeys which mean you now miss the connection at preston for squires gate then its not a good difference this has made
  27. hexagon789
    6,282
    2 Sep 2016
    I appreciate they've increased some just now, but will they not reduce the ones they've increased to less than what the were before they increased them though?
  28. Llama
    Llama Member
    960
    29 Apr 2014
    319s are not capable of 100mph between Salford Crescent and Bolton. You'd be lucky to get above 90.
    In the other direction 95 is attainable, however there is a longstanding short 75mph TSR after Kearsley so 95 is only really likely down near Clifton at the moment.
  29. Llama
    Llama Member
    960
    29 Apr 2014
    Looks like the guard was doing his best not to increase the journey time on that trip...
  30. ComUtoR
    5,856
    13 Dec 2013
    Do you drive them ? How do you find them (if you do) I hope they improved them from their time down South. Are they still !$£$ in the wet ?
    Cheers in advance.
  31. The Planner
    The Planner Established Member
    9,222
    That is just being unlucky and ending up at Euxton at the same time as the Liverpool Blackpool goes by, then the Lancaster Euston in the other direction. Both the Northerns stopping at Leyland too which requires 2N60 to be on the fasts.
Share This Page
