hexagon789
I thought the 25s in two-tone green looked quite smart when new out of shops.
They do in my opinion as well, so do the 27s. Two-tone green looks best on a 47 though, but that's just my opinion.
The GE not having type 4 power is no surprise: there were no hills to need it! What type 4 locos that were available were better sent elsewhere.
As to why the WCML getting class 40s and not Peaks, my guess is that they had little choice. The BR workshops couldn't keep up with a decent rate of production while EE could - so EE got more orders even though the product was inferior, and someone had to use them once they were built. The LNWR got the short straw
In the 1970's the Edinburgh-Glasgow service was half hourly all day with one train per hour non stop from Haymarket to Queen Street and the other making one stop at Falkirk High. There may be more trains today, but they stop more frequently and are therefore slower end to end than forty five years ago.But probably a sight more reliable than the 27s. And in the 1970s there were rather fewer train services out there than now - opportunities to thrash trains all the way on the limit are rather harder to find in 2018.
This is a misnomer. The GE mainline, as one of the lesser engineered mainlines, is extremely up and down. They more or less layed the railway over the rolling hills of Suffolk and Norfolk! Indeed, the climb out of Norwich alone up to Dunston from the stops would have been a challenge for a type 4 with 14 on, on a summer Saturday.
Suffolk and Norfolk? Hills? Come on, you're having a laugh
No mirth here. I'm not pretending there are any 6 mile one in eighty climbs through the fells, but barring the Acle-Yarmouth, Downham Market-Lynn, and west of Brandon towards Ely, Suffolk and Norfolk railways and the GEML as a whole are seriously undulating, with some challenging gradients!
I'm sure many students of loco performance are aware of Brentwood bank. And the climb out of Liverpool Street is quite sharp too.
I can't remember the spec in detail but it permits a very wide range of voltage and either AC or DC, probably a range of frequencies too. 750V is probably within the limits for the nominal 1000V.Bit of an off topic- but related to the regional preferenes thing.
When Electric Train Heating was adopted by the southern, it appears they adopted 750V (dc?), I assume so they could use third rail power directly on the 4REPs and 73s etc etc
Why, when the other regions adopted ETH, did they not adopt the same standard rather than a nominal 1000V supply?
(Is ETS/ETH on non HST units DC or AC? I can imagine it might even be both as required because the only loads originally will be things like series wound motors and heaters that can run on either)
I’ve been up Cowlairs bank on the Fort William sleepers in the 80s behind a 37 (I seem to remember that being a fairly big load actually), and it was some struggle with wet rails and a roaring exhaust as it kept slipping while trying to get some purchase. It must surely have woken the people in sleeper carriages!From videos I've seen, the climb out of Queen St seemed to produce pleasing amounts of thrash from locos.
Yeah, I've done that on the sleeper. Amazing.I’ve been up Cowlairs bank on the Fort William sleepers in the 80s behind a 37 (I seem to remember that being a fairly big load actually), and it was some struggle with wet rails and a roaring exhaust as it kept slipping while trying to get some purchase. It must surely have woken the people in sleeper carriages!
Even in the mid-1970s bankers were still employed here, typically the loco which had brought in the incoming stock. Class 47s to Aberdeen and Class 27s on West Highland trains were assisted out of the station and up the bank. On right away, horn from the train loco, and horn from the rear loco, which then started to push. Departures from the east side platforms would be out on the inbound side of the approach tunnel, then over the crossover at the tunnel mouth to the outbound track, by when if both crews had used full power quite a speed might be obtained, and the unattached banker would make a notable rock and roll as it negotiated the crossover. The morning 2x27 push-pull I regularly took to Edinburgh was preceded by an Aberdeen-headed Class 47, and I always went to the platform end before departure to watch the spectacle.From videos I've seen, the climb out of Queen St seemed to produce pleasing amounts of thrash from locos.
That or a Shove Duff
47/7's were great fun blasting up the Queen Street tunnel.
Most of the drivers seemed to give them some hammer.
Sounds like quite the performance. The only videos I've seen are all late 1980s, 1986-1990. In all those, no loco hauled trains were banked, did the practise end towards the mid to late '80s do you know?
From the mid-1980s until dmus arrived, all the Glasgow - Edinburgh fasts, and most of the Aberdeen services were booked for 47/7 + push-pull set, and these were not banked.
