Milton Keynes Central after 04:29 and before 09:51;
assuming that you mean the return portion of a Manchester to London Any Permitted off-peak return then it is:-Query re an off peak London to Manchester ticket. The return portion, if i broke journey at Milton Keynes, can I then take any train from there to Manchester on another day?
Not valid on trains timed to depart:
London Euston after 04:29 and before 09:26 or after 15:00 and before 18:45;
We've had this discussion just recently. Manchester to London is a regulated flow and the Any Permitted Off-Peak Return is the regulated ticket in this case. Regulated tickets may not have evening restrictions upon travel outside the 'ring' of Reading, Watford Junction etc. VTWC use restriction 2C to reflect this.assuming that you mean the return portion of a Manchester to London Any Permitted off-peak return then it is:-
I'm not aware of anything that says you may board a barred train later on in its journey.
It seems an absurd proposition to me that two tickets with the same restriction code can have a differing validity from the same station, merely because of their origin/destination!A Manchester to Milton Keynes return off peak ticket has no afternoon restriction from MKC as it is a regulated ticket.
A Manchester to London Ticket does have an afternoon restriction and would not be valid for return during the restricted period.
Any ticket always retains the restrictions of that ticket even if you break your journey.
Regulated ticket rules apply to the origin/destination of the ticket not to where you board the train
Presuming you are referring to fares regulation, I was advised the opposite by the DfT (albeit with the caveat that they told me that this was a opinion rather than a definitive statement of law), which is why some GWR (regulated ex-SVR) SSR restriction codes permit travel from Reading after 19:00 even when the train departed Paddington before 19:00 (such that it is barred for passengers boarding at Paddington but permitted for those boarding at Reading).Regulated ticket rules apply to the origin/destination of the ticket not to where you board the train
More favourable to the consumer, that is! Some TOCs prefer to interpret it as whatever is more favourable to their coffers.the Consumer Rights Act suggests that the more favourable interpretation should prevail
I agree with this. Otherwise restriction codes could change multiple times if you decided to break your journey en-route.
The Euston restrictions may not apply to a Milton Keynes ticket but they do apply to a London Terminals ticket.It's the same cack-handedly worded restriction from both. Indeed, the wording is "trains departing from" which would technically mean the EUS restrictions apply to MKC, though clearly they actually don't.
I find it hard to believe that this can be true. Restriction code 2C's text doesn't refer to the ticketed origin or destination anywhere. If you are departing from a station then you must check what the restrictions from said station are. Checking what the restrictions upon previous stations are is ludicrous and that is why journey planners are not required to do so.The Euston restrictions may not apply to a Milton Keynes ticket but they do apply to a London Terminals ticket.
As I said in another thread recently, I would argue that, read literally, the restrictions on departing Euston still apply even on a ticket to Milton Keynes. Restriction 2C is a bodge job in my opinion; Virgin should have moved the Milton Keynes fare to a different restriction code after they were shown to be non-compilant with fares regulation. I don't think 2C is a very good example of a restriction code to be generalising other rules from!It's the same cack-handedly worded restriction from both. Indeed, the wording is "trains departing from" which would technically mean the EUS restrictions apply to MKC, though clearly they actually don't.
Maybe I should try it out and take it to Court if I'm excessed, to have the matter adjudicated!
It would be a fun exercise. In fact, if I had the money to throw around, I'd consider getting a declaratory judgment to decide either way - before I actually make the journey.Good luck with that... nothing like this ever goes to court.
As a layman when it comes to ticketing I must say that both arguements make sense which suggests a fundamental flaw in the way that the restrictions are defined.
