Bromborough Rake to Southport
Discussion in 'Fares Advice & Policy' started by Lukeo2311, 10 Nov 2011.
Thread Status:
  1. Lukeo2311
    Lukeo2311 Member
    39
    10 Nov 2011
    Canberra ACT Australia
    I am wanting to travel Bromborough Rake to Southport via Chester on a Sunday, I am curious to know if a guard would question my intentions going via Chester. and yes I know there is a direct service to Southport from Chester in the current timetable.
    Rail Forums
  3. bb21
    bb21 Moderator Staff Member Moderator
    23,054
    4 Feb 2010
    If you have a Bromborough Rake - Southport ticket, you're not permitted to travel via Chester.
    Your origin and destination share a same routeing point in the shape of Liverpool Group, hence the only permitted routes are on a direct service or the shortest route (and those no more than 3 miles longer). AFAIK you are only allowed to travel via Birkenhead and Liverpool.
  4. yorkie
    yorkie Administrator Staff Member Administrator
    40,016
    Welcome to the forum! :)
    It depends on the guard, but I could certainly see some questioning that!
    Permitted routes are defined in the Routeing Guide.
    Unfortunately Bromborough Rake [[stn]BMR[/stn]] and Southport [[stn]SOP[/stn]] share a 'Routeing Point' in common (Liverpool Group), therefore the only permitted route is the direct route via Birkenhead, Liverpool and Formby. Sorry!
  5. raildude
    raildude Member
    95
    24 Oct 2011
    Nantwich
    Would a Saveaway ticket not be valid?
    You would be travelling by rail only between two stations in the Merseyside area.
  6. bb21
    23,054
    4 Feb 2010
    Depends on what the itinerary the OP had in mind. If he intends to travel to Chester then back via Merseyrail to Southport then a Saveaway is probably the correct ticket.
    I fear that the OP had in mind the idea of going via Wigan and Warrington, in which case a Saveaway is not valid.
  7. Eagle
    Eagle Established Member
    7,106
    20 Feb 2011
    Leamingrad / Blanfrancisco
    I think he had in mind the idea of going via Northwich, Manchester, Bolton and Wigan (which is a direct service on a Sunday).
  8. bb21
    23,054
    4 Feb 2010
    If it is a direct service between Bromborough and Southport then it is valid on a point-to-point ticket, however I don't believe that he can alight at Chester.
  9. Eagle
    7,106
    20 Feb 2011
    It's direct between Southport and Chester (a Northern 150 IIRC).
    Pretty certain it's invalid on a Bromborough ticket.
  10. MikeWh
    MikeWh Established Member Senior Fares Advisor
    5,399
    15 Jun 2010
    Crayford
    Correct. Two tickets would be required for that journey, one from Southport to Chester and another from Chester to Bromborough Rake.
  11. Lukeo2311
    Lukeo2311 Member
    39
    10 Nov 2011
    basically I'll using a saveaway from Bromborough then getting a separate Chester - Southport ticket then travelling Southport - Bromborough via Liverpool. so another I pose if i purchased a Chester - Southport at would that permit me to travel on the direct service or not?
  12. MikeWh
    5,399
    15 Jun 2010
    Crayford
    There seems to be a word or two missing from that question, so I'm not certain exactly what you're asking. I'll pre-empt some possibilities though.
    A Chester to Southport ticket would be valid both via Liverpool and on any direct train. If it's a return then you can go one way out and back the other. You cannot use part of the return ticket before then using the outward as the outward ticket is only valid if you have an unused return portion. You couldn't therefore do the circle from Bromborough Rake on a Chester to Southport return.
  13. Lukeo2311
    Lukeo2311 Member
    39
    10 Nov 2011
    I would be getting a one way ticket from Chester to Southport then using the saveaway back to Bromborough as I'll be getting an all zones one to get to chester on the first leg of the journey
  14. Eagle
    7,106
    20 Feb 2011
    That's perfectly valid for your itinerary, then.
  15. raildude
    raildude Member
    95
    24 Oct 2011
    Nantwich
    You only need a Chester to Meols Cop ticket as the Saveaway is valid from there to Southport according to the map.
  16. scrapy
    scrapy Member
    967
    15 Dec 2008
    True but this is exactly the same price as a Southport to Chester ticket!
Thread Status:
Share This Page
