Tom said:
Hmm, I also remember the fact that the Watford Junction Metropolitan Line link took around 4 months to organise and we still got no-where, whereas you installed a crossover at Nottingham station and got it approved same day as application... oh the wonders of bias.
Let me add a couple of points in before this gets any further.
There was a previous thread about this a while back and I seem to have received a Strike for it and you personally never explained to me why I got it. And to add to that the thread and post in question have been deleted from public view. Biased? Perhaps. Resorting to using Moderator Control Panels wrongfully? Perhaps.
The post I quoted above I and other have explained to you numerous times and yet ignored it. An entire extension of the Met Line does require some discussion whether it's economically viable or not. Engineering staff can't say "Yes. Go ahead" straight away and it requires more thinking and looking at plans you provided. You provided little detail and drew a map based on the current LU to extend the line via Watford High Street. The Engineering staff then have to find out what exactly you are doing because you have failed to post details etc. The engineering team don't have 12 hours a day to run I-NR!! Since you haven't provided sufficient detail the engineering team have to find the plans themselves. Time consuming.
Now this crossover. Very little work and planning is needed for a additional crossover. IIRC The crossover plans had a Simple Diagram and reasons for it been built. Nothing major a crossover and it went ahead because it increased efficiency in Nottingham.
An additional Crossover and LUL Extensions are in two different leagues, as Tomnick has clearly pointed out.
Depends on the format really ... the only reason why we have RailNetwork on here is because another one shut down and some of us wanted to continue with it.
The game format is still subject to partial Copyright to the original authors of which you never asked for any sort of permission for it to go ahead. RN is a near complete copy of I-NR.
BTW I'd be most greatful if you didn't delete this post and give me a ban for no apparent reason. That be grand!
