Bus Simulator 2018
Arriva Fan
14 May 2018
Hi All,
I would like to buy Bus Simulator 2018, and would like to ask some experienced simulators for their advice on computer specs required for these games.
My current laptop is a Samsung Series 3 Notebook. Would I need something a little more powerful to run Bus Sim? And if so, what would you guys recommend? What do you use when you are simulating?
Thanks all.
bnm
12 Oct 2009
Here are the Bus Simulator 18 system requirements (minimum)
  • CPU: Intel Core i3 with 3.3 GHz or AMD Phenom II X4 with 3.2 GHz
  • CPU SPEED: Info
  • RAM: 6 GB
  • OS: Windows 7/8/10 64-Bit
  • VIDEO CARD: NVIDIA GeForce GTX 750 (1GB VRAM) or AMD Radeon R7 360 (2GB VRAM) or higher
  • FREE DISK SPACE: 6500 MB
Bus Simulator 18 Recommended Requirements
  • CPU: Intel Core i5-4670 (4rd gen.) with 3.4 GHz or AMD FX-8370 with 4 GHz or equivalent
  • CPU SPEED: Info
  • RAM: 8 GB
  • OS: Windows 10 64-Bit
  • VIDEO CARD: NVIDIA GeForce GTX 970 (4GB VRAM) or AMD Radeon R9 290 (4GB VRAM) or higher
https://www.systemrequirementslab.com/cyri/requirements/bus-simulator-18/17759
I'm using a home built PC that easily exceeds the recommended requirements. Even if your laptop matches the minimum CPU and RAM specs above I doubt your integrated graphics will come close to being suitable.
Arriva Fan
14 May 2018
  • CPU SPEED: Info
  • RAM: 6 GB
  • CPU SPEED: Info
  • RAM: 8 GB
Thank you, I'll check these against my Laptops Specs.
Is anyone using a Samsung Series 3 to run a Simulator Game? How does it perform?
Could anyone recommend a good pc for simulator gaming?
