Buses with the passenger heaters on in hot weather.
miklcct
2 May 2021
Cricklewood
If the heater doesn't switch off then it's a fault just like any other. A driver who is suffering discomfort because it it's too hot is not a safe driver as it's a distraction. That's even before you consider the effects on the passengers!
It will be a piece of news if a driver end up getting heat stroke as a result of the vehicle being too hot!
cnjb8
26 Feb 2019
There was only one 57 reg Solo SR which was the very first one made, which appears to have been scrapped three years ago. Anyway, the system is the same on all diesel Solos - the vents at the rear of the passenger saloon are for heating and very effective in the winter if everything is connected properly. They have a negligible effect on cooling the engine down if it is running hot, having the demisters on at the front is much more effective.
I think the question that needs to be asked is - do you want the bus to stop moving for 10-15 minutes while it cools down, or do you want it to keep going? The railways don't keep going at full speed when it's unusually hot, so why would you expect a bus to?
It was involved in the February 2018 floods that flooded Marshalls depot in Sutton-on-Trent
Mikey C
11 Feb 2013
Sounds bizarre that the heater has to be left on to stop the bus overheating, though the other day - not the full heatwave weather, but still well over 20 - the heater at the back of a Metroline E200 was partially on. Apart from the heat, it makes an awful racket.
Cesarcollie
5 Jun 2016
Works with a (classic) Mini ....!!
