Buying an add-on to normal journey?
paulfoel
6 Jan 2014
Normally get a 7 day season for newport-gloucester.
One day next week I want to continue on to cardiff (and return to newport). Is it valid to just buy a return from newport-cardiff?
Should I explain to guard and but ticket from him when he checks tickets as normal just after leaving Gloucester?
bnm
12 Oct 2009
If facilities are available you should buy at Gloucester station before boarding. If the ticket office is closed and there are only TVMs then yes, you can buy on board as the TVMs won't sell a fare with origin Newport.
And yes, a return from Newport to Cardiff is correct.
paulfoel
6 Jan 2014
Right. So at Glos I can buy a newport-cardiff return?
Or I guess I can get off at newport and buy lol.
bnm
12 Oct 2009
Yes you can and must buy that ticket if the ticket office is open. If closed then buy on board. No need to alight at Newport.
If the ticket office is closed it's best to be proactive and seek out the guard on the train, although you aren't compelled to do so. Saves any hassle should the guard not come through the train and you arrive at the gateline in Cardiff without the additional ticket. Even then, without having seen a guard, you should be allowed to purchase it there.
Flamingo
26 Apr 2010
If you know what day you need to travel, you can buy the Newport-Cardiff ticket any day in advance (at a booking office or from the guard on-train), just ask for it to be dated for the appropriate day.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
Not relevant here, but not only is it valid but with a season and non-season the train you take need not even call at the "changeover" station (it must pass though though).
If the ticket office is open you must buy the ticket at Gloucester.
...or disembark at Newport. There's no harm in getting on the train if you don't have time to buy a ticket, as long as you don't leave Newport without one. Most guards will happily sell you a ticket if asked before you get there.
paulfoel
6 Jan 2014
Yes because surely Im obliged to buy my ticket for cardiff-newport asap. So asap is on the train on the way to newport surely? for whch I've already got a valid ticket.
Merseysider
Fares Advisor
22 Jan 2014
I would definitely try to obtain it before going past Newport to avoid any accusations of over-riding or travelling on a short season.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
Definitely before Newport; from what I've read ATW are being pretty proactive in clamping down on short-faring at Cardiff.
I am of the opinion that you are entitled to the full range of tickets from the guard at any point before Newport. Some TOCs however insist that staff only sell Anytime tickets onboard (except where no opportunity to buy) - if you find this to be the case and wish to save the 30p difference between Off Peak and Anytime Day Return fares you can buy at Newport if you have been unable to get the ticket before travelling.
paulfoel
6 Jan 2014
Just realised I should probably have just bought a monthly cardiff - glos instead of newport - glos. 40p more so these odd journeys would have been covered.
Im guessing no issue with getting off at newport most days?
Merseysider
Fares Advisor
22 Jan 2014
I think if you took your Newport season to a staffed station they could change it to the Cardiff season, for a proportional cost.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
I think if you took your Cardiff season to a staffed station they could change it to the Newport season, for a proportional cost.
Yes, you could, provided that at least 7 days validity remain.
No problem getting off at Newport - it might not work the barriers but this has no effect on validity, someone will let you out.
paulfoel
6 Jan 2014
Surely barriers will work? In the past, I've got on at bristol parkway (got lift from glos to there) and barrier worked getting onto station.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
AIUI barriers must be programmed specifically to accept tickets which are not destination/origin there. Some stations are better than others.
paulfoel
6 Jan 2014
Be a right PITA then not having the barriers work at newport all the time then if thats the case. And then having the argument that yes even though it says cardiff its valid from newport too. (they are a bit dull at newport).
