C in train reporting numbers
LWB
31 Dec 2009
I have been looking through RTT for my area (S.Cumbria) and find that most movements are xCxx type. I have searched for the meaning of C but it doesn't appear on any sources such as here or Winkipeed. Is it new, (Cumbria perhaps)?
Many thanks
John Webb
5 Jun 2010
St Albans
'C' usually indicates a train running within a area for a particular destination.(In BR days different letters were associated with different divisions of a particular region and with a particular terminus. I'm not quite certain how this has been translated onto the 'privatised' railways.)
Is it possible that 'C' in this case may indicate 'Carlisle'?
A-driver
9 May 2011
Quite simply the letter relates to the trains route/destination.
In a head code like '1C23' the 1 at the start indicates an express passenger train (2 for normal passenger train, 3 for high speed empty stock or freight, 5 for normal empty passenger stock etc etc...).
The letter indicates the trains route and destination and the last 2 numbers are just a unique code to avoid confusion. So you may have a 1C23, 1C24 and 2C23 all running in the same area at once but never the same exact code at the exact same time.
The letter won't always make any sense. Some do, however others don't. For example on the GN routes from kings Cross xPxx will indicate a train for peterbourgh, xCxx indicates Cambridge which both seem fairly obvious but xTxx indicates kings Lynn or Ely, 2Vxx is a welwyn train, 2Bxx is Hertford etc.
LWB
31 Dec 2009
John and A-driver..... thanks for the replies. That all makes sense, of course not all are running as xCxx, only 'local' trains eg Barrow-Carlisle. Just couldn't find it referenced anywhere.:)
TheEdge
29 Nov 2012
Norwich
I often wonder the logic in headcodes.
London to Norwich are 1Pxx, Norwich to Yarmouth is 2Pxx unless via Reedham when its 2Cxx and Lowestofts are 2Jxx. East Suffolk trains are 2Dxx and Felixstowe is 2Rxx. None make any sense.
At least Sheringhams are 2Sxx.
LWB
31 Dec 2009
Well there you are! Today's trains up and down the Cumbrian coast line are 2C33 through 2C45. I suppose there's no confusion with a train down there!
W230
6 Jan 2012
Likewise. I assumed there would be some, but there isn't it seems (not on TL anyway)!
xExx - Sevenoaks services.
xTxx /xWxx Bedford - Brighton
xOxx / xVxx Sutton loop via Mitcham/Wimbledon.
Yabbadabba
23 May 2014
That is because the Thameslink route has to fit in with all the other codes on Kent & Sussex. This is the reason why London Overground's ELL trains run as class 9s as we have simply run out of alphabet for class 1s & class 2s on the former Southern Region.
306024
23 Jan 2013
East Anglia
There doesn't have to be much logic so long as the head codes are unique within a signalling area at least 6 hours, and preferably 12 hours apart.
Shenfield, Southminster and Southend all begin with S, so no chance of using initial letters.
LBSCR Times
17 Sep 2013
Sussex born and bred
There isn't any....
London Bridge - Brighton 1B
Victoria - Brighton 1A
Victoria / London Bridge - Ore 1F
Victoria / London Bridge - Littlehampton 1H
Victoria / London Bridge - Portsmouth / Bognor 1C
But then the Gatwick Express are 1D on the Down and 1U on the Up!
The 4 digit headcode has to be unique, as there are 2O in the Victoria ASC for both Milton Keynes and Thameslink services!
EM2
16 Nov 2008
The home of the concrete cow
T denotes via London Bridge. W denotes via Elephant & Castle.
You'll find a list of area codes in the Working Timetable index for each area, which are on the Network Rail website.
http://www.networkrail.co.uk/browse... timetable (WTT)\1 - December 2014 - May 2015
Unfortunately there isn't an index to the areas, each of which is denoted by a two-letter code where the first letter is that of the former Regional planning office responsible. We eventually find that CF is the correct area and the CF index file gives C as Cumbria.
Which we could probably have guessed anyway.
causton
4 Aug 2010
We do on the Great Northern...
2Pxx for Peterborough calling semi-fast
1Pxx for Peterborough fast to Stevenage
2Cxx for Cambridge semi-fast
1Cxx for Cambrige fast to Stevenage
2Rxx for Royston semi-fast
1Rxx for Royston fast... you get the idea now?
We then have some that are not quite obvious, such as
1Txx for Kings Lynn/Ely/non-stop to Cambridge
2Jxx for all stations from Hertford North
2Kxx for all stations from Welwyn Garden City
2Uxx for all stations from Letchworth via Hertford
2Bxx for all stations to Hertford North
2Vxx for all stations to Welwyn Garden City
2Fxx for all stations to Letchworth via Hertford
Obviously these may change during the peaks (i.e. 1Pxx can terminate at Huntingdon, 2Uxx can start at Stevenage) but it gives a rough guide of where they're going at each junction and crossover to the signaller hopefully!
A-driver
9 May 2011
Non stop to Cambridge only is 1C. 1T is only for trains heading to Ely or beyond.
Flamingo
26 Apr 2010
Paddington to Bristol and West Country HST's are 1CXX (with the exception of 1C01 which passes through Bristol Temple of Doom but ends up in Swansea).
Class377/5
19 Jun 2010
xExx is via Catford (Blackfrairs services)
xGxx Beckenham Junction (Thameslink)
Sometimes the number that starts is meaningless. For example at East Croydon a 1Bxx is a London Bridge to Brighton stopper and a 2Bxx a Tonbridge.
Its all a general sty of rules but it isn't set in stone.
jopsuk
13 May 2008
From St Pancras, a 1F could be either a SouthEastern High Speed via Faversham or an EMT to Sheffield. But they are on effectively entirely separate systems.
Taunton
1 Aug 2013
I believe when the 4-character system was devised (around 1960) the letter was taken from the appropriate destination area, within the region, letter of the working timetables, which were already coded A, B, C, etc. Over this, inter-regional trains were given an letter for the destination region as a whole, and these were meaningful, apart from the Western Region (used V) and Southern (used O), as W and S were already taken.
It was desired to have 4 characters because the Western Region had the old GWR system of large 3-character train numbers displayed on the front of the locomotive, including the first diesels, and this was extended to include the train class, previously shown by lamps, as the first character.
Regarding duplicates, the Southern had their own two-digit electric train headcodes, and someone once pointed out that four separate trains could be leaving London Bridge side-by-side on different services, all with the same code.
hairyhandedfool
14 Apr 2008
And for completeness, O is Streatham-Sutton-Wimbledon-Streatham and V is Streatham-Wimbledon-Sutton-Streatham. On the Brighton and Sutton Loop trains, odd numbers are southbound, even numbers are northbound.
Class377/5
19 Jun 2010
Unless it's changed in the December timetable (haven't checked every headcode in the new one), that's not actually true. Mostly it is but some trains don't follow this pattern. For example the the 12 car trains off Brighton in the evening peak used to be (prior to Dec) 1W94, 1W95, 1W90.
TheJRB
14 Feb 2011
Ashford, Kent
On Southeastern:
xAxx - Up Maidstone East via Beckenham Jn, up Charlton and Blackheath
xBxx - Up Greenwich, Catford Loop
xCxx - St Pancras loop out via Gravesend return via Ashford (1Cxx), up Bexleyheath
xDxx - Up Sidcup, Sheerness to Sittingbourne, up Beckenham Jn and Herne Hill
xExx - Down Greenwich, Tonbridge to Tunbridge Wells
xFxx - High Speed via Faversham (1Fxx), up Petts Wood and Chislehurst (2Fxx), Maidstone East via Catford
xGxx - Sole Street and Grove Park
xHxx - Hastings (1Hxx), Tunbridge Wells (2Hxx)
xIxx - Cannon Street loop out Sidcup return Greenwich
xJxx - High Speed via Ashford (1Jxx), up Bromley North, down Cannon Street to London Bridge short workings (none in current timetable)
xKxx - Sole Street and Catford, up Hayes
xLxx - St Pancras loop out Ashford return Gravesend, down Blackheath and Charlton
xMxx - Down Bexleyheath, down Herne Hill and Beckenham Jn
xNxx - Down Sidcup, down Maidstone East via Beckenham Jn
xOxx - Cannon Street loop out Greenwich return Sidcup
xPxx - Up Sole Street and Beckenham Jn, down Bromley North, up London Bridge to Cannon Street short workings
xRxx - Down Headcorn
xSxx - Down Beckenham Jn and Sole Street, down Chislehurst and Petts Wood (2Sxx)
xTxx - Medway Valley
xUxx - Victoria to Dartford
xVxx - Down Hayes
xWxx - Up Headcorn
xYxx - via Catford Bridge and Beckenham Jn
bb21
Emeritus Moderator
4 Feb 2010
So you are confirming what he said, the way I read it.
Class377/5
19 Jun 2010
Not sure how you can come to that conclusion. He stated. ...
I've already given examples where both odds and even are used in the same direction, hence the above post isn't true. Is a general rule yes, but don't assume that is always this way.
bb21
Emeritus Moderator
4 Feb 2010
Ah, I see your 1W95.
It's the even numbers you gave either side of it that confused me.
whoosh
3 Sep 2008
Odds and evens.
I think it's odd numbers to Cannon Street and even numbers to Charing Cross for South Eastern.
badassunicorn
8 Jul 2012
C on the great eastern indicates a move to Gidea Park Station or yard. Normal Shenfield metros are W, and ICS is V.
LWB
31 Dec 2009
Thank you Edwin! I searched around there but missed the last bit!
Class377/5
19 Jun 2010
Its worse when you watching a signaling panel and think shouldn't that be going the other way?
Flange Squeal
17 Jul 2012
SWT - General off-peak format
xAxx - Waterloo to Alton
xBxx - Waterloo to Poole
xCxx - Waterloo to Reading
1Dxx - Waterloo to Dorking
2Dxx - Waterloo to Guildford (via Epsom)
xExx - Portsmouth to Southampton
xFxx - Waterloo to Woking/Guildford
1Gxx - Waterloo to Portsmouth (via Cobham)
2Gxx - Waterloo to Guildford (via Cobham)
xHxx - Waterloo to Shepperton
1Jxx - Brockenhurst to Lymington Pier
2Jxx - Waterloo to Hampton Court
xKxx - Waterloo to Waterloo (via Kingston & Richmond)
1Lxx - Waterloo to Salisbury/Exeter St Davids
2Lxx - Waterloo to Basingstoke
xMxx - Waterloo to Chessington South
1Nxx - Waterloo to Aldershot/Guildford (via Ascot)
2Nxx - Ascot to Guildford
xOxx - Waterloo to Waterloo (via Richmond & Kingston)
1Pxx - Waterloo to Portsmouth Harbour (via Guildford)
2Pxx - Waterloo to Haslemere/Portsmouth & Southsea
xRxx - Waterloo to Waterloo (via Richmond & Hounslow)
xRxx - Salisbury to Romsey
xSxx - Romsey to Salisbury
xSxx - Waterloo to Weybridge (via Hounslow)
3Sxx - MPV circuits
xTxx - Waterloo to Portsmouth Harbour (via Eastleigh)
xUxx - Waterloo to Windsor & Eton Riverside
1Vxx - Salisbury to Bristol Temple Meads
2Vxx - Waterloo to Waterloo (via Hounslow & Richmond)
xWxx - Waterloo to Weymouth
5Yxx - Waterloo to Clapham Yard (empty coaching stock)
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
On the east coast main line, the codes for long-distance passenger services changed in 2011. I think they now are :
1Ann Southbound to London from Leeds Hull Harrogate Sunderland Bradford and Skipton
1Ynn Southbound to London from Newcastle (or Berwick) and York
1Enn Southbound to London from Edinburgh, Glasgow, Inverness and Aberdeen (and some from Newcastle)
1Dnn Northbound to Leeds Harrogate Bradford and Skipton
1Hnn Northbound to Hull (or Beverley)
1Nnn Northbound to Newcastle Sunderland and York
1Snn Northbound to Edinburgh, Glasgow, Inverness and Aberdeen
1Bnn both Southbound and Northbound between London & Lincoln
