Calder Valley line improvement works
superkev
1 Mar 2015
west yorkshire
Looks like the work to extend Sowerby Bridge platforms is to start next week.
The Hall lane.Halifax, Milner royd, Hebden bridge boxes are due to close 23rd Oct with signalling transferred to York ROC. Most new signals seem to be in place with more capacity promised. Doesn't seem to be much if any increase in line speed. Signalling Man Vic to castleton remains manual.
Hebden Bridge car park is to be extended an a lift installed. Progress?
There are rumours that the Class 170's and the new Transpennine stock won't fit through some of the tunnels west of Hebden Bridge. Anyone know more?
K
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Calder Valley was number one on Northern Sparks priority list - all party report. I know that is a moot point now but the more that gets done -signaling etc, means the cost will be a little less later if it does eventually get sparked up.
Spartacus
25 Aug 2009
I'm surprised 170s didn't occasionally go that way when TPE had them? If not it might just a be a case of them not being cleared rather than not fitting. I know they ended up on a few lines where they weren't cleared when TPE had them, before it was realised. I'm looking at something which suggests they're not cleared via Harrogate (nor are 180s through Mirfield)
Regarding clearances on new stock, didn't they solve issues with 185s simply by moving the steps a bit and shaving platform edges?
deltic08
26 Aug 2013
North
170s have cleared themselves as they have been running on the Harrohate Loop for a few months now.
Bungle965
Buses & Coaches
2 Jul 2014
Blackley and Broughton/ Walsall South
There was an article of platform extensions kicking off in a few months time, it was only from the local news so only gave info that Littleborough, Smithy Bridge and Mills Hill would get attention. However is there any other?
Sam
Sam
Paul Bigland posted on these earlier this week including photos of work at Hebden Bridge and Sowerby Bridge.
https://paulbigland.blog/2018/08/16/calder-valley-rail-improvements-progress/
The following stations will see platforms extended by varying lengths, with work due to finish by December 2018.
Mills Hill. Smithy Bridge. Littleborough. Walsden. Todmorden. Hebden Bridge. Mytholmroyd. Sowerby Bridge and Bradford Interchange.
Bungle965
Buses & Coaches
2 Jul 2014
Thanks for that!
I do wonder what they are planning to do about Moston. Half of the Leeds bound platform is in a completely derelict state since the freight wagon smashed into it. The last I heard about it Network Rail and DB were at odds as to who was to pay for it.
Up until now anything longer than 3 carriages and the rear unit would be locked out.
Sam
Calderfornian
17 Jan 2018
Lifts have been surveyed from what I understand. Car park involves reorganisation of the coal merchants’ yard. Platform works ongoing tonight (again).
Calderfornian
17 Jan 2018
K
Re TPE stock, it’s a diversionary route at weekends so it would seem a bit weird if it wasn’t cleared.
61653 HTAFC
18 Dec 2012
Another planet...
185s are cleared. The TPE 170s were always a micro-fleet and when Calder Valley diversions were in place, the Hull 170 services tended to run as shuttles to Huddersfield (even on the old 4tph timetable, there weren't paths via Hebden for all 4) so there was no need to clear the 170s that way. In any case I'd be surprised if anything major was required to clear them, as they aren't significantly fatter than 185s which, again, are cleared.
Just realised you meant the new stock, apologies. On that, the Mk5a sets shouldn't need significant work in theory As they're 22m vehicles, and haven't 68s already run that way on excursions? 802s on the other hand might require more work, and if one of the tunnels is an issue (something was mentioned somewhere in the last few days IIRC) the costs might mount up...
Calderfornian
17 Jan 2018
Platform 2 extension has been surfaced and hoardings we’re going up this morning for the lift works
lincolnshire
12 Jun 2011
K
I think your date is in-correct as 23rd October is a Tuesday so guess it could be weekend of 20th/21st October .
deltic08
26 Aug 2013
North
Do you mean a 170 has never run on the Calder Valley route in all these years?
Halifaxlad
5 Apr 2018
The White Rose County
When going past the site of Bowling Junction earlier today I couldn't help but notice that some of the vegetation had been cut back, that is a little bit strange as it wasn't anywhere near fouling the track. Does anybody know if this is something to do with the possibility of the Bradford 'Avoiding Line' being reopened, as it did seems to be on the old trackbed?
AndyW33
12 Aug 2013
Well, when you look at the TOCs that have used them, only TPE ever might have, and it has already been explained why their very small fleet didn't need to.
Let's face it, there's little reason why Scotrail, MidlandMainline, Hull Trains, Anglia and successors, Central Trains, or South West Trains would ever have wanted to send theirs that way, even on the most inspired of ORCATS raids. After the fleet cascades and franchise changes that rearranged the 170s, there's still no reason why LM and successors or Cross Country or Chiltern (whose 170s have anyway become 168/3s) or Southern (became 171s) would have been involved either.
Really, it is only now that they have arrived with a TOC that actually operates the Calder Valley route on a daily basis that the issue has arisen.
NorthernSpirit
21 Jun 2013
There's some blue piping fencing at either end of the platforms at Brighouse, so could Brighouse also have its platforms extended too?
55z
21 Nov 2014
Class 170's not yet passed to run on Calder Valley Line unless things have changed recently (the sectional appendix says no to 170's) Lifts to be built at Hebden Bridge as part of the governments access to all scheme. Platform extension (eastbound) at Hebden Bridge is due to signal overlap being sub standard at east end and probably train lengths. Class 180's are passed to run Greetland Jn to Hebden Bridge and Milner Royd Jn to Dryclough Jn as Northern hire in for one journey in morning peak and another in evening peak Hebden Bridge to Leeds via Bradford Interchange. As far as I know the TPEXP mark5a coaches have not operated for gauge clearances Liverpool/Manchester to Scarborough. It is up to the TOC/FOC to request route clearance unless the unit/coaches/loco have grandfather rights.
superkev
1 Mar 2015
west yorkshire
At Sowerby bridge short eastwards extensions to the platforms are being progressed at night during the past 2 weeks. Looks very expensive for not a lot (about 8m) of platform.
The waiting shelters have been repainted and relaxed over the past 6 weeks. Pity painting couldn't include the tatty canopy. Pics-
K
superkev
1 Mar 2015
west yorkshire
I hear that network rail are going to attack the steelwork in at least one of the tunnels between Hebden and Todmorden to give presumably to give clearance for the 170's and MK5s.
No idea when but probably sooner than later as the bin liner train clearence is marginal too.
K
coxxy
16 Aug 2013
In the next couple of months Mills Hill is having a lift installed on the rochdale bound platform and the ramp receiving some attention so it isn't as steep on the Manchester bound platform. Would imagine they would do platform work at the same time...
Halifaxlad
5 Apr 2018
Went to Network Rail's engagement session the other week at Brighouse, picked up one of their glossy leaflets, attached is the map inside that shows what stations will have platforms lengthened and when, interesting Bramley & New Pudsey don't feature.
Eccles1983
4 Sep 2016
Moston won't need doing as it only gets served by the Rochdale turnbacks which at best is a 4 car service
Ships
25 Apr 2013
Mostons being rebuilt after the freight train mashed it, might be rolled up into those works?
