Caledonian Sleeper Class 92's
Discussion in 'Traction & Rolling Stock' started by Mag_seven, 17 May 2016.
  1. bastien
    bastien Member
    427
    14 Aug 2016
    Employers should "provide protection from falling objects" - for example, a heavy chain.
  2. Charlie Smythe
    Charlie Smythe Member
    378
    18 Aug 2018
    Exeter
    Well that is mental. Just wear a hard hat or something and be careful.
  3. bastien
    bastien Member
    427
    14 Aug 2016
    I should probably leave this, but I've done enough work for Health and Safety organisations to know: a) People get horribly injured at work so often it's not funny and b) The reasons are often completely banal and avoidable. Sorry, I'll get off my hobby horse.
  4. 59CosG95
    59CosG95 Established Member
    4,469
    18 Aug 2013
    WIM/PBO
    I should point out that it is good practice to try and avoid sending fitters down below the coaches with hi-vis and helmets at the design stage; CAF have essentially designed the risk of injury out of the coupling with the use of Dellners (which also conveniently transfer the required ETS through the train without the need for connecting nearly as many jumper cables).
    Besides, a hard hat is next to useless against a pair of buffers crushing an engineers' skull laterally.
  5. 43096
    43096 Established Member
    6,454
    23 Nov 2015
    The Dellners do not transfer the train supply on the sleepers. If they did, they wouldn't need ETH jumpers.
    One point: the existing stock, Class 92s excepted, has auto-couplers as they have Buckeyes. The Class 73s did too before they were retro-fitted with Dellners. Only major difference is the air connections, which are presumably auto on the Dellners. It does beg the question why drop-head Buckeyes have not been fitted on the new stock with the Class 92s modified as well.
  6. xotGD
    xotGD Established Member
    2,627
    4 Feb 2017
    Folks,
    Can we talk about the locos on the loco thread, the coaching stock on the coaching stock thread and the showers, blankets and breakfast on the general wibble thread.
    Cheers
  7. ScottDarg
    ScottDarg Member
    610
    27 Apr 2017
    South Lanarkshire
    92044 on Carstairs tonight; 018 in Edinburgh for 1M16 so that leaves 028 for 1M11
  8. sd0733
    sd0733 Established Member
    1,587
    7 Nov 2012
    92020 was out today with its Pantogtraph up paired with 92032 at Crewe, 032 had it's pan down
  9. TimboM
    TimboM Established Member
    3,544
    12 Apr 2016
    Both 020 and 032 had pans up coming out of the ETD into the station.
    032’s was just down momentarily as the driver swapped pans on 032 to run the locos back to the ETD.
    020’s first run on the mainline under her own power since April 2001!!
  10. sd0733
    1,587
    7 Nov 2012
    Ah ok, sorry, I only saw it for a few seconds, must have been the small amount of time it was down.
  11. GrimShady
    GrimShady On Moderation
    1,740
    13 Dec 2016
    Will all the 92s in the CS pool receive the Midnight Deal livery?
  12. 43096
    6,454
    23 Nov 2015
    Or even Midnight Teal.........
    Other than 92006 at Brush only those locos that have received CS livery so far will be receiving it.
  13. Far north 37
    Far north 37 Established Member
    1,793
    13 Apr 2011
    92014 off the garston car job 66787 now taken over.
  14. TimboM
    3,544
    12 Apr 2016
    Ran off on Saturday to Crewe... https://flic.kr/p/QxmsZt
    Then to Wembley on Sunday where it's now on B Exam.
  15. Highlandspring
    Highlandspring Established Member
    2,392
    14 Oct 2017
    92010 on 1M16 was in bother overnight with loss of air at Beattock Summit; 90048 was made ready to assist but in the end wasn’t needed and the train is currently running about half an hour late around Shap.
  16. Scotrail84
    Scotrail84 Established Member
    2,128
    5 Jul 2010
    That loco has failed twice in the past few weeks or so, something not right with it.
  17. TimboM
    3,544
    12 Apr 2016
    Was failed at Waverley last Wed night and Mon night and replaced by the Carstairs engine both times. Worked OK Thu and Sun night.
    Signallers unusually generous to 1M16 and left if on the Fasts in front of a LIV-EUS Pendo (1R05) - arrived Euston 8L vs public timetable.
  18. ScottDarg
    ScottDarg Member
    610
    27 Apr 2017
    South Lanarkshire
    92020 has worked its first revenue-earning return trip since being reinstated. It ran light to Garston Car Terminal Yesterday to work the empty cartic wagons down to Dagenham on 6L48: https://flic.kr/p/RpimT6
    It then worked back to Garston overnight with the loaded train on 6X41: https://flic.kr/p/T2pS6u (pic by TimboM)
  19. Mag_seven
    Mag_seven Established Member Associate Staff General Discussion
    5,851
    1 Sep 2014
    here to eternity
    The aforementioned 92006 has today been released from Brush and was hauled to Crewe H.S. from where it should undergo some test runs over the next few days.
  20. TimboM
    3,544
    12 Apr 2016
    And here she is... and yes, that is 92006 moving under her own power on the mainline for the first time in 13 years after panning up first time and booting up without so much as a grumble.
  21. Far north 37
    1,793
    13 Apr 2011
    Great video tim whats the next plans for it a run out on the cars soon?
  22. TimboM
    3,544
    12 Apr 2016
    Test runs to start with - all being well will be out on the WCML over the coming days. Stafford and/or Preston are possibitlies for tomorrow.
    May not get to go on the cars as last I heard there was an issue with the diesel shunter at Dagenham, so needs to be 66s so they can go into the sidings themselves and haul their own trains out.
    So there's a chance it may go direct to the Beds once its "passed" its testing.
  23. sluf
    sluf Member
    171
    15 Aug 2016
    92033 in teal livery was stabled at Preston in the RES sidings yesterday morning. Any ideas why?
  24. TimboM
    3,544
    12 Apr 2016
    Awaiting collection by 006 very shortly...
    It’ll then go to Crewe (with 006) for some TLC and also to act as insurance for the 006 test runs (not that 006 seems to need bay so far).
  25. axlecounter
    axlecounter Member
    386
    23 Feb 2016
    Switzerland
    Don’t think my question deserves a new thread:
    In the failed CS brakes thread I’ve read multiple times that a running brake test wouldn’t probably have pointed the problem out since when doing it Class 92 applies its rheostatic brake. Simple question: can’t the driver apply air-brakes force only? Even better, like we do down here, apply only the coaches air brakes excluded those of the loco? Thanks
  26. captainbigun
    captainbigun Member
    953
    3 May 2009
    92, as is common on all ex BR AC locos you can isolate the rheostatic brake (and/or re-gen though not used) or not. That’s a depot, fault finding or prep job.
    When driving you then have the auto air brake which is loco and any trailing vehicles. In the case of the loco brake it will be rheostatic blended with friction as required, especially at low speed where the current drops off.
    In addition there is the loco straight air brake, which as it says is loco friction brake only.
  27. BRX
    BRX Established Member
    2,397
    20 Oct 2008
    Why is re-gen not used?
  28. TimboM
    3,544
    12 Apr 2016
    92s can do this, but (if at all) only when working HS1/Tunnel.
    There's no re-gen when running on Network Rail - my assumption would be that the OHLE / power supplies aren't set up to cope with it (or at least no-one wanted to spend the money on ensuring it was / taking the risk if it wasn't).
  29. BRX
    2,397
    20 Oct 2008
    Surely the OHLE is set up to cope with all the other train types that use regen braking though?
  30. themiller
    themiller Member
    647
    4 Dec 2011
    Cumbria, UK
    Surely the WCML can cope with a 92 as they have Pendolini regenerating - or do they not?
Share This Page
