Can anyone please tell me the consist of
5S07 1349 Carlisle to Polmadie Car M.D on Friday 15th March?
I don't know whar the hold up has been exactly, but per the general sleeper thread, latest is Lowlander going to new stock at the end of April, and Highlander at the start of June.
all services switch to Mk5 operation or will it be a gradual change?
It’s feasible to work the Lowlander with old stock in one direction and new stock in the other. You’d need a couple of extra locos in the mix and it’d be a bit of a headache, but doable.There has to be a full switch over on each route because...
By only 92's and 73/9's will work with the Mk5's and they aren't exactly the most reliable loco's.It’s feasible to work the Lowlander with old stock in one direction and new stock in the other. You’d need a couple of extra locos in the mix and it’d be a bit of a headache, but doable.
92s and 73/9s are as reliable as anything else these days.By only 92's and 73/9's will work with the Mk5's and they aren't exactly the most reliable loco's.
It is a bit of a headache as you won't have 86/87 for ECS working's.
There’s various ways it could be planned, but most likely scenario is more locos being required - simplistically an extra Mk5 ECS engine at Wembley and an extra Carstairs loco.I was thinking that as I wrote it - you presumably would either need a 73/9 for the Carstairs portion, use the 1M16 or 1S25 engine as appropriate or explicitly have a different engine each way. Or does the fact that the Carstairs is only eight coach mean that an unmodified 92 can haul it with Mk5s?
So sorry for posting to the incorrect thread. I now know where to ask any similar questionWrong thread buddy - you need to post it in the TOPS request thread under the Diagrams sub forum...
Many thanks for replying to my incorrectly placed post.73970, 15007, 15105, 15205, 15314, 15333, 15332, 15331, 15330
Two additional 92s being added to the fleet which’ll make up for the 86s/87 going.
There has to be a full switch over on each route because:
a) the class 92s need to be set up to provide 1500V power to the Mk5s and the same locomotive works the Carstairs portion of both north and southbound lowland sleepers
b) the same carriages work the 'day' portion of the Fort William sleeper on the same night/morning.
New Mark 5s.So the saloon carriages added at Edinburgh for Fort William will need to operate on 1500v?
Are these new Mark 5s or is existing stock being converted?
It’s the ETS supply coming out of the locos that has the different voltage - not the coaches.So the saloon carriages added at Edinburgh for Fort William will need to operate on 1500v?
In the April issue of Modern Railways it says that the new stock will be in service in July, is this a mistake or has it been delayed again from June?
Don't believe everything you read in the railway press.
Yes - the very first 'shadow Lowlander' back in January was a full Load 16 with Edinburgh portion and Carstairs join/split operations. Since then it's only been half-sets.Are they yet to run a 16 coach set then?
There's still only 56 of 75 coaches in the country.
The eight test runs over the last two weeks between Glasgow and London (4 in each direction) have all been the same 7 coaches.
2x 16 sets ready in 4 weeks time?
4x 16 sets + spares ready in 9 weeks time?
How quickly are they being delivered?
Fair enough, in which case I don't know why they keep giving out the dates that they do. I know the passengers passing on the info very well and they won't be mistaken about what they've been told, so there must be some duff information doing the rounds within CS.There's still only 56 of 75 coaches in the country.
I don't doubt that's what they're being told and that's still the target / official launch date.Fair enough, in which case I don't know why they keep giving out the dates that they do. I know the passengers passing on the info very well and they won't be mistaken about what they've been told, so there must be some duff information doing the rounds within CS.
Tickets were previously sold for the new stock on the Lowlander from late October (2018) when that was the planned launch date for that service. It's now five months later and still no sign of the Mk5s on the Lowlander.On the Caledonian Sleeper website you can still by tickets for the new sleeper trains from June 2nd which must mean it is still quite possible to introduce the new stock by this date as otherwise would they not have removed these tickets?
