BRX
- Joined
- 20 Oct 2008
- Messages
- 3,627
That's odd, when I travelled on the sleeper just a few weeks ago I'm sure several tables had reserved signs on them.
Lazy Shunter at Aberdeen? Went up double headed ,came south topped and tailed.When leaving Aberdeen this evening, I noticed that the sleeper stock has 66746 in Royal Scotsman livery on one end and a 73 on the other. Was there a problem with the 73 last night?
Train fault, there's a bit about it on CS Twitter.I notice realtimetrains.co.uk shows this evening's 21:15 Euston to Inverness/Aberdeen/Fort William as still being at London Euston as of 23:05.
ETH fault, was initially thought to be a defective sleeper coach but fault has persisted after it was knocked out.Edited: The Highlander just got cancelled at 23.35...
ETH fault, was thought to be a defective sleeper coach but fault has persisted after it was knocked out.
Yes - 90044 which was the 5S95 engine and due to work 1S26 Lowlander is still trapped.Is this going to impact the Lowlander as well, as that is usually hauled by the locomotive which brings the empties in for the Highlander - which is obviously trapped at the buffers until the Highlander departs?
92033 being collected from Wembley to work 1S26 instead, however don't think it's even left Wembley yet, so that'll be an hour+ late leaving itself.
There's a fair bit of slack in the timings and could miss out Watford as you say. Weedon looks to be under possession now, so no savings there.Should make some of it up; last week we gained 32 minutes with a 92 up front. They can probably gain even more if they shift the Watford passengers to Euston to board there so they don't have to stop at Watford, and unless there's engineering that would prevent this, they could gain a bit by running via Weedon instead of Northampton couldn't they?
Usually only do that if very late.Might make sense to run it through to Glasgow and transfer the Edinburgh passengers like they have done a few times? Saves 14 minutes at Carstairs, not counting any gain from not having to slow down and then pull away again...
There's also likely to be displaced Highlander passengers who are on balance better off being in Edinburgh than Glasgow.
Think it's just showing that so the signaller knows it's the full train re-formed after all the shunting about. It's still showing caped.Interesting... the Highlander just changed from 5S00 back to 1S25 on Open Time Trains...
Makes sense.Think it's just showing that so the signaller knows it's the full train re-formed after all the shunting about. It's still showing caped.
It is - and it did stop/split as you'll probably know!As to my earlier comments, at most they'd gain 12 minutes by not splitting at Carstairs - it's a booked passenger stop in the timetable isn't it...?
I see the Edinburgh to Fort William section has run, I guess it would have just been the seated element. I wonder if there will be an attempt to move the sleeper part during the day?Think it's just showing that so the signaller knows it's the full train re-formed after all the shunting about. It's still showing caped.
That’s a brute of a cancellation. I was trying to book on that very train, but it was full (the Inverness part, at least). What can CS do? Offer people seats on the Chieftain?
