- Joined
- 15 Apr 2008
- Messages
- 15,963
Is that 6 car related at Aber or just 4 ?? as didn't they join up two 158s when the new re-furb was shown ?
The 0807 Mach to Aber weekday commuter (arr c0844) train gets shunted into run round loop to allow the 0624 ex New St to arrive (0925) in platform at present. The ex New St unit then forms 0930 to BHM INTL. The ex local working unit then runs ecs to Mach after it in time to get into coast loop at Mach to work the c1100 to Pwhelli which connects with the 0809 ex INTL which was only 2 car on weekdays.
As the 0809 ex INTL is now a 4 car all week that splits at Mach for Aber and caost the unit off the local working should connect up with unit off 0624 ex New St at Aber and then join up with unit off coast at Mach to got forward as 6 car unit.
So ATW are saying 2 separate units cannot join up at Aber station due to ertms even though it happens 6 times a day at Mach.
Not read the whole of the thread, but I have to say if the fact that fence stops longer trains being run, the world has gone mad.
Its not 3 units being joined up at Aber but 2. It happens 6 times a day at Machynlleth on a shorter platform in between sets of points and with the potential of conflicting moves on the adjacent lines the track layout at Aber is now far more simplified than Mach.
The incidents at Llanbadarn Fawr LC in recent years have all had separate causes. Since ertms was commissioned there's been charters run to Aber with locos running around, 4 car DMU formations have turned up occasionally and every day a 158 shunts into the loop to allow another one to arrive at the platform.
I really cant see what the problem could be with a 4 car DMU triggering the LC at Llanbadarn once it departs Aber and goes past the treddle. One 158 sits in the platform and another joins up with it before departing eastbound is all that can happen! What possible "risk" is there? If there worried about them splitting then why aren't the rest of ATW operations on Cambrian and to BHM INTL 2 car only?
Not read the whole of the thread.
None of the situations at Aberystwyth you mention cover the joining and splitting of trains. Did the original scope of work for the installed system allow for this to happen? If it did has it ever been trialled and proved to work correctly?
Contributary factors in the recent incident reported on by the RAIB at the level crossing were the drivers workload and the lack of interface between the signalling system and the automatic crossing. These are not trivial matters and should be given the necessary study and not dismissed out of hand.
What happens at Machynlleth is irrelevant - pre-ERTMS, they were permissive platforms (under TCB regs, presumably) and provision will have been made under ERTMS for that to continue. I doubt that there was any provision for permissive working at Aberystwyth under RETB - it would have been possible to make shunts to attach or detach, I'm sure (as opposed to bringing an arriving train in on top of one), but probably not within the turnaround of the service in question.
Sufficient to simply join two units, but is it sufficient to allow the second to be shunted from the loop to the platform within that ten minute window (after faffing about getting the movement authority after the ex-B'ham unit arrives)?The working tt gives arriving units 10 min turnaround at Aber at moment more than sufficient to join up 2 Class 158's.
You should try reading the whole thread then because the rest of your post is misinformed nonsense
Split/ joining happening- as a previous poster mentioned the first refurbished 158 was previewed at Aber last April (after ertms) by this method.
Driver Workload- I would suggest there is scant difference between running around attaching/ detaching from LHCS trains and a pair of DMU's joining up on the platform. In fact the latter is probably less of a workload. Yet from the pile of charter runs ( c6) I've just seen announced in RAIL Mag as confirmed to run into Aber they seem to be going ahead.
With all respect,this is 2012 with all the latest technology only a few miles down the line,why on earth can they not be joined up,after all they are the only two movements on the line within the station for two hours.
It just seems that providing a better service for passengers is an interference with the comfort zone.
My opinion of course
Bob
Bringing a running movement (as the arrival from B'ham would be) into a platform on top of something already in there is a significant departure from the basic signalling principle of "one section, one train", and as such the ability to do so (in normal working) is only provided where it is justified. I don't know how the ERTMS is set up, but it's possible that the movement authority to approach Aberystwyth station can only be issued from a fair way out (as I'm sure used to be the case in RETB - Borth, I think?). You certainly wouldn't want to be issuing any authority to come in on top of one in the platform from that distance.With all respect,this is 2012 with all the latest technology only a few miles down the line,why on earth can they not be joined up,after all they are the only two movements on the line within the station for two hours.
There are quite a few sections on the approach to Aberystwyth from Borth, one marker board on the Aber side of Llanbadarn crossing, one at the entrance to the up sidings and one mid platform.
What's the crossing got to do with anything? It's been mentioned in this thread as one of the 'problems' encountered so far with ERTMS, and a factor that might be affected by the additional workload with setting ERTMS up after coupling two units, but the crossing itself isn't the reason why the platform can't be worked permissively.The logical conclusion of these comments is that no trains should be running at all now if using the crossing is such an issue..Bustitution from Borth?
Those not familiar with Aberystwtyh the LC at Llanbadarn is some way from the station not at the end of the platform or in site. The buffers are 95m 60ch, No 1 GF 95m 30ch and Llanbadarn (ABCL) 94m 56ch.
Yes, we've established that. We've also established that a unit can shunt to the loop and back, and could (I'm sure) shunt from the loop to couple to a unit already in the platform. None of the above involve an arriving train (a running move as opposed to a shunt) being signalled into an occupied platform at Aberystwyth, and I think you'll find that's where the problem lies; that's the movement that (probably) hasn't been provided for in the ERTMS installation.There has to be movement authority with ERTMS as there's been LHCS Charters whose locos run round arrive at Aber since ERTMS.
Do you really think it is ok to bang two trains together and drive off when there seem to be a fair few issues to sort out in the ERTMS implementation and the proceedures in use?
correct - I've seen someone walk into the platform one whilst taking a photo as were on the theme of safety!
Locomotives arriving at Aberystwyth and running round a train is not the same as two trains arriving independently then coupling and returning as a single train. My understanding from the press was that there were lots of issues with joining and splitting trains at Mach before the ERTMS system was successfully commissioned. Has the work to ensure these problems don’t recur been done at Aberystwyth? The single incident you mentioned earlier in the thread for a special event may not be particularly meaningful as special arrangements may have been made for a one off.
The location of the level crossing about 1 mile from the buffer stops is very much part of the problem as described by the RAIB report. I suggest you read it. The combination of leaving in a degraded mode, running brake test, difficulty of control of speed, recovery from late departure and requirement to operate a timing plunger helped to create the conditions for the run through of the level crossing. If the level crossing was at the platform end or 5 miles away there would not have been the same problems for the driver.
Now I expect it will be possible to ensure trains can be split and coupled at Aberystwyth and safely depart over the level crossing but is cannot be a surprise that coming up with a satisfactory technical and/or procedural method takes time and may in the short term prevent coupling at Aberystwyth.
remember ertms is suppose to be magic answer to everything - clearly we can see it isn't if such simple things as DMU's coupling up cant be done- the clues in the name. If it holds back badly needed and overdue improvements for passengers then I will only criticize more. It may all be a jolly technical wheeze for some but remember the Cambrian is an operational railway used by over 1.5 million people per annum. Its a living used railway not a playset for signal engineers/ enthusiasts.
