Camera memory card
mac
15 Dec 2010
Going on holiday in 10 days so got camera out, it's a 6 year old Canon power shot a530 never been used much but handy in pocket. When I put new memory card in it comes up card locked what do I need to do to get it working
Waldgrun
13 Oct 2011
According to Cannon this camera takes both SD amd mmc cards.
So it's likely you are using an SD card. Which has a lock on it to unlock slide the switch on the left hand side upwards (contacts facing away from you).
Unlock the card, ironically enough! There will probably be a very small switch somewhere on the card (an edge most likely) flick it and try the card again.
mac
15 Dec 2010
tried lock on side but nothing changes. On front of card it says hc and on back fc
Crossover
4 Jun 2009
If it is the "HC" I am thinking of, it may mean High Capacity - could it be possible that the camera doesn't support it?
How large is the card you are trying to use? Since it appears they came shipped with a 16MB card, it may not support some of the newest, largest ones
mac
15 Dec 2010
This sounds right I had a 1GB card in and it works fine new one is 8 which is smallest in shop. I will have to look for another 1GB Thank you
507 001
3 Dec 2008
Huyton
If you can find a 4gb that should work. 4gb cards are not classed as high capacity cards.
D365
29 Jun 2012
The camera only supports the original SD specification. The only size that Sandisk supply in the UK is 2GB. Amazon Product Link
Regards
Bushy
Yep, that's probably the only 'traditional' SD card which you'll easily find new today. Exactly the one I have, though got it cheaper than listed there.
Harpers Tate
10 May 2013
Agreed. SD cards (without HC or XC) go up to 2gb. That's probably the smallest capacity you will find currently. So that's what to buy and use. 2gb.
