overthewater
- Joined
- 16 Apr 2012
- Messages
- 8,169
Can you join two train carriages together with passengers on them?
Of course, happens at numerous places daily on Southern and southeasternCan you join two train carriages together with passengers on them?
Depends on the TOC. Merseyrail passengers must be detrained first
Why is that ? Is it because it's likely to be underground, is it due to the type of stock, or is it just Merseyrail deciding to be different as usual ?
LNR will do it with passengers on at Northampton but not at Euston...
...and it’s one of many.There is already a thread here:-
www.railforums.co.uk/threads/coupling-and-uncoupling-with-passengers-on-board.178987
This subject comes up almost as often as datum plates...
You can’t uncouple without staff present at what would have been the intermediate gangways. I don’t think your “safety” factor is real. Preparing the cab/gangway area to now be the end of the unit requires manual intervention, outer doors closing and locking, hinged cab equipment to be repositioned, the door to the train switched to crew operation etc etc.But with 497 pages of threads one can be excused for not doing an exhaustive search.
I've been on GWR 387 units that coupled at Paddington before allowing passengers off. But uncoupling is, maybe, a different matter due to the need to safely seal off the passenger access between each 4-car unit, e.g. avoiding danger to passengers moving between the units.
In answer to the thread title - no, you have to use a proper train coupler !!!
That’s not quite the same as the OP’s question, one unit will be going out of service, or entering service.Liverpool to Norwich seperates 4 car 158's into two 2 car 158's at Nottingham!
I presume it also couples together again at Nottingham with passengers on board.
Yes Virgin WC Class 221s couple and uncouple with passengers, no problems normally.
It's the best way of serving several destinations using a single path over a particular busy line.
