Cardiff Tidal - Aberthaw tanks?
12 Dec 2009
Carmarthen
While watching a Locomaster DVD just now, it showed a 37 on the 10 or so TEA tanks on the Vale of Glamorgan line circa 1999. The liquid cargo is obviously needed for something at Aberthaw but I have not seen this working at Cardiff in recent years. If the flow has stopped, what was it needed for, seeing as Aberthaw power station is still in active operation?
7 Nov 2009
Newcastle
What type of power station was/is it? Some can run on a combined cycle of coal and oil.
Power stations can also take in/send out other things such as bulk powder for the production of plasterboard and also there are different chemicals needed if there is a flue-gas desulphurisation equipment fitted.
Hydro
5 Mar 2007
I'm sure some coal power stations used to use fuel oil for something or other? Maybe for diesel balancing generators?
142094
7 Nov 2009
Newcastle
Might be for priming the furnace - I've had a tour of Drax and they do regular summer maintenance so some of the furnaces are offline. Starting them back up again isn't an easy job, so guess this could be the reason for the tanks.
heart-of-wessex
11 Jun 2005
Trowbridge
There is an oil unloading point and coal unloading point at Aberthaw. The Locomaster Double O cab ride has a pair of 37s going to the Aberthaw oil unloading point...can't remember if it said why or what for though
12 Dec 2009
Carmarthen
Yes, I have seen that great DVD. I still haven't taken notice what this working is or was. Anyone care to describe what the tanks were for at Aberthaw???
33056
12 Nov 2007
On a train somewhere in Europe
Is the correct answer. Don't know how often it runs, not very frequently; in this picture I took in 1994 is was running with a "Z" headcode and was served from Minimet in Cardiff Docks.
Pacerpilot
7 Jun 2010
Again, I have no idea what the Oil is for but its run at least twice this month. I cant remember exactly which days, but Ive seen it on the middle roads at Cardiff Central twice, 66 hauled on both occasions.
trainfanatic
4 Jan 2010
Big Sky Country - Sleaford
Aberthaw, like many of its ilk, requires copious amounts of Heavy Fuel Oil to start its boilers. Only when certain operating parameters are met will coal in finer than face powder form, will beintroduced to the furnace. The boilers also require oil burners to be started if the number of coal crushing mills falls below a certain amount. This is for main coal flame stabilisation and usually occurs if the generator load drops to around 300MW.
I have many happy memories of commissioning oil burners at Aberthaw.....
Pacerpilot
7 Jun 2010
Superb....thanks for that. Ive seen the train run countless times but had no idea what the oil was used for.
