Carto Metro London rail map v3.10 now available (uploaded yesterday)
Rogmi
7 Nov 2013
Franklin uploaded the the latest update (v3.10) to the online and downloadable London rail map yesterday.
From the site:
"Last updates : Bank diversion, Minor corrections (Aldgate East)"
The track layout changes due to take place east of Epping at the weekend have been included. Hopefully the changes went ahead :)
Downloadable PDF version
Ideal for regular use and use with larger screens. Handy if using the map as a reference. The PDF map gives the highest resolution (6400% magnification) and allows all the tiniest details to be seen that might otherwise be missed.
Online version
Same details as the PDF map, plus the online map is interactive
Ideal for use on mobiles etc. when out and about
Select a station. A pop-out will allow you to:
Toggle between the London Lines map (also downloadable) London map
View the area on Google / Bing maps
Next train departures (LU and NR)
As always, if anybody has any feedback regarding the map, please contact Franklin (email details are at the bottom of the site page) or post here
rebmcr
15 Nov 2011
St Neots
I believe Paddington (H&C) platforms might need to be re-added to the fully-zoomed-in detail level in v3.11 (... For Workgroups?).
Edit: Royal Oak is similarly afflicted.
Rogmi
7 Nov 2013
I spent ten minutes trying to find where the problem was as everything looked OK. Thought - "let's look online" and saw what you meant :)
The PDF download (which I always use) is OK and so it must be a hiccup affecting the online version. Thanks for that. I'll let Franklin know and I'll also try and look around the online map to see if I can see anything else obvious.
D365
29 Jun 2012
Apologies for the (somewhat) off-topic but is the Epping to Ongar reconnection brand new?
Rogmi
7 Nov 2013
No. Originally (in theory at least) there was still a connection. Whilst, I assume, the running rails are still continuous, what they have effectively done now is taken the connection away. Where Epping joins the Ongar branch (at the LU border), back-to-back train arrestors have been fixed. Think of these as buffers. They form a permanent barrier to movement over the line border. A train overrunning the Ongar branch will be stopped at the arrestor on its side, a train overrunning Epping station will be stopped at the arrestor on the LU side.
That's assuming that the work was carried out this weekend.
D365
29 Jun 2012
Ah. So it’s not as exciting as I had first hoped!
Dstock7080
17 Feb 2010
West London
The work was completed as you describe
Rogmi
7 Nov 2013
Thanks. Very basic. I was expecting something a bit more bulkier, but then nothing should hit either of them at any great speed. Looks simple enough to remove if transfer to / from the Ongar branch is required.
Rogmi
7 Nov 2013
Franklin has reuploaded the online map, and it now shows Royal Oak, Paddington, and other station platforms that were missing.
The update information was also shown incorrectly and this has also been changed to:
rebmcr
15 Nov 2011
St Neots
I have just discovered Blackfriars (District & Circle) in the same condition on the reissue.
Rogmi
7 Nov 2013
Thanks, I'll let Franklin know. Apparently the problems have been caused by a software update.
It's strange, because the platforms only disappear when the online map is zoomed to maximum. They show at all other times.
subk2010
18 Feb 2021
What happened to Aldgate East?
Is that the crossover between Aldgate East and Whitechapel was removed?
Dstock7080
17 Feb 2010
West London
Yes, removed 8/9 February 2020
Was to have been replaced by new 9A/9B 10 points at Tower Hill when SMA 3 was due to be commissioned in March 2020. Unfortunately these won’t be commissioned when SMA 3 goes live next week and are likely to be removed.
Rogmi
7 Nov 2013
The changes to Aldgate East on map v3.10 were for the disused Aldgate East. The WB platform is now shown in the correct place (on the H&C), the new District line curve (from 1938) is date labelled and the original District line curve position has been added.
