Central Line RAT trains
AndyHA
1 May 2009
Bishop's Stortford , Hertfordshire
What I am after is the make up of the two Central Line RAT stock . I guess they were converted from either 1959 & 1962 stock .
At this stage I am Not interested in times , just what the trains are . Do they carry their previous stock numbers , or were they renumbered into London Underground’s Service stock series ?
From a passing southbound Met Main Line service , I note one was right over the back at Neasden Depot , yesterday 07th-Septembe-2021 , but which one ?
Thanks in Advance
Dstock7080
17 Feb 2010
West London
1962 Stock, still retain original numbers:
5-car
1570-9591-2440-9441-1441
8-car
1406-2682-9125-1681+1682-9577-2606-1407 recently undergone overhaul Acton Works.
Mojo
7 Aug 2005
I saw the 5 car train at Ruislip depot either Monday or Tuesday this week, so unless it was moved overnight on Monday then I’d take it that the train you saw at Neasden was the 8 car one.
1 Feb 2018
I took the train from Princes Risborough to Marylebone on Tuesday and I can confirm the 5 car RAT was out on that side of the depot, beside the Central running lines if that helps
Mojo
7 Aug 2005
Having been to the depot this afternoon, I could only see 3 cars, not sure if the other 5 are in the depot for work, or elsewhere.
Supercoss
5 Jun 2016
slight change to painted numbers posted above
Ruislip set 5 car
1570 DM
9691 ndm
2440 T
9441 ndm
1441 DM
Hainault set 8 car
1406 DM
2682 T
9125 undm
1681 DM
1682 DM
9577 ndm
2406 T
1407 DM
Dstock7080
17 Feb 2010
West London
"Runs as Required" only
West Ruislip 0512 0626 0951 1109 1410 1530 2051 2211
North Acton 0607 1012 1434 1508 2153.
Epping 0446 1103 1503 2212
Leytonstone 0511 1037 1535 2141.
Arthurfical
24 Mar 2021
Brighton
Thank you, I’ll give it a go then! Is this timetabled to run every day as required?
Dstock7080
17 Feb 2010
West London
When did the 62 stock get converted into a RAT train?
The Central had a Sandite car 9459 while the 1962 Stock was still in passenger service.
The 8-car train continued running on Sandite duties after the other passenger trains were withdrawn.
The 5-car westend unit was converted in 2010.
