I'm uncertain what 'chain guards' are. Were these some form of protection against dangling coupling chains on goods wagons?Good morning,
I was out walking in Scotland for a few days and used a few foot crossings and farmers crossings.
I noticed none of them had chain guards on the decks.
Are chain guards no longer a requirement?
As @John Webb was wondering, what exactly do they protect against? Damage to the leading edges of crossing surfaces?Are chain guards no longer a requirement?
They bounce dangling couplings up rather than them getting caught under the boarding and destroying the crossing in the process.As @John Webb was wondering, what exactly do they protect against? Damage to the leading edges of crossing surfaces?
Yes !Are these what you mean. Here’s a picture from Network Rail showing a crossing with the items indicated.
The angled plates just show the word “STRAIL”, being the manufacturer of the crossing components.Wild guess, they are solar cells to power the little LEDs the mark the edge of the crossing.
I assume it's a coupling that might be dangling, therefore it's in the middle. If it strikes a rail on a set of points then it will be pushed off to one side and probably just ride over the rail and swing back once it is pushed far enough - and a rail is a lot more robust than a crossing panel. AWS magnets have a similar ramp. TPWS grids don't but they are well below rail level. Facing point locks had these historically too, possibly because although they are well below rail level a coupling striking them could move the point blades under the train. This may also be one reason why modern point machines aren't between the rails and the actuating rods are often top of sleeper level.They shouldn’t be needed at all as nothing should dangle below rail level as it will hit a lot of other stuff and dash itself against points. So what were they for? Although the railway has long had a ’belt and braces’ attitude, are they really intended to prevent something that has come loose from catching, but if so why only in the middle?
new warning system to improve safety at level crossings in anglia
The AWS magnet on trains is fixed so doesn’t dangle. However,AWS ramps have coupling guards to protect the magnets. Here’s a photo of one showing the guard.i thought their current usage would be to protect against damage from the AWS detector on trains passing over the crossing.
If the AWS receiver is that low there's a problem.i thought their current usage would be to protect against damage from the AWS detector on trains passing over the crossing.
The AWS receiver is fixed in position under the train, at a height of around 4-6 inches above railhead (from memory).I have no idea as i was unable to find anything online that showed how it worked under the loco. Anyone know of anything?
It would be quite tricky to negotiate pointwork if it did...The AWS receiver is fixed in position under the train, at a height of around 4-6 inches above railhead (from memory).
It absolutely does not need a ramp to stop it hitting track objects.
The top of an AWS magnet is significantly higher than the top of a TPWS loop. And putting a metal plate on top of or even within a TPWS loop is probably going to prevent it working.Mixed LO/LU lines use similar wooden ramps over TPWS loops to deflect the centre contact shoe on underground units. Not quite relevant in Scotland, but there's numerous reasons that a ramp would be added.
Considering TPWS was invented much later than AWS, it can be assumed that the lack of ramps (on TPWS loops) is due to older stock with the risk of dangling chains/couplers no longer being in use. AWS ramps are older, so it is likely just a leftover from their design. It's cheaper to install a mass-produced plate of metal than to justify removing it from the design.
I don't understand what you are trying to say. TPWS loops still needed a ramp on mixed LU lines because the centre contact shoe would strike and damage it, so they added wooden ones. There's no reason they couldn't add wooden ramps to all TPWS loops, but it has obviously been deemed unnecessary because they don't have them. There is no reason to put a metal plate on top of a TPWS loop, and nobody ever suggested doing this? It absolutely would attenuate the signal and prevent it from working.The top of an AWS magnet is significantly higher than the top of a TPWS loop. And putting a metal plate on top of or even within a TPWS loop is probably going to prevent it working.
An LU centre contact shoe would surely never drop far enough to hit a TPWS grid, as they have to deal with points I believe they cannot ever go much lower than the height of the fourth rail, and that is about 1.5” above the running rail.I don't understand what you are trying to say. TPWS loops still needed a ramp on mixed LU lines because the centre contact shoe would strike and damage it, so they added wooden ones. There's no reason they couldn't add wooden ramps to all TPWS loops, but it has obviously been deemed unnecessary because they don't have them. There is no reason to put a metal plate on top of a TPWS loop, and nobody ever suggested doing this? It absolutely would attenuate the signal and prevent it from working.
You are right, I completely forgot about points and fourth rail height. This image (Harlesden Station) shows that the TPWS loop is much lower, the wooden ramp is more likely just to prevent any arcing to the loop. As the wooden part raises the height of the loop slightly, the ramps may just be there just as a precaution to prevent damage.An LU centre contact shoe would surely never drop far enough to hit a TPWS grid, as they have to deal with points I believe they cannot ever go much lower than the height of the fourth rail, and that is about 1.5” above the running rail.
I suspect it’s more likely the wooden section is there to keep the shoe at nearly the fourth rail height, for when it runs back onto the rail?
I assume the shoe is held down by spring pressure to maintain contact with the rail. That being so, when it runs off the end of the rail might it momentarily bounce down below normal height before coming to an equilibrium?You are right, I completely forgot about points and fourth rail height. This image (Harlesden Station) shows that the TPWS loop is much lower, the wooden ramp is more likely just to prevent any arcing to the loop. As the wooden part raises the height of the loop slightly, the ramps may just be there just as a precaution to prevent damage.
