Chesterfield - Sheffield via Barrow Hill
DynamicSpirit
12 Apr 2012
SE London
As discussed on this thread, one of the proposals the DfT have shortlisted for further consideration as part of the Restoring your Railways fund is restoring passenger traffic on the Barrow Hill line.
Rail Technology Magazine has published more details of this proposal here. I don't seem to be able to copy and paste any of the text from that article, but it seems to be saying that the proposal is to build some stations along the existing Barrow Hill freight line (and new stations along the Sheffield-Retford passenger line), as well as improving signalling to allow passenger trains to run, and then have a service that would go something like:
  • Chesterfield
  • Whittington
  • Barrow Hill
  • Renishaw/Eckington
  • Beighton
  • Woodhouse
  • Waverley
  • Darnall
  • Nunnery Square (change to the tram for City centre)
  • Sheffield Victoria (not the existing Sheffield station because of likely capacity issues, and in the hope of regenerating the area around Victoria).
(Existing national rail stations in italics)
Seems an interesting idea to me, although I notice looking at the map that a lot of the proposed stations are some distance from the communities they'd purport to serve.
adrock1976
10 Dec 2013
I'm not too familiar with the railway geography of that area, but I thought a station at the site of the ex Midland Killamarsh West could be reopened.
This could be named as Killamarsh & Halfway (for Sheffield Supertram) being as those are reasonably large settlements next door to each other, albeit one is in Yorkshire and the other is in Derbyshire.
30907
It is also not well sited, and I suppose it would abstract from Supertram? also
If it happens, would it be worth switching the Retford line services to Victoria, thus easing the pressures on the northern approach to Midland, or is there too much longer-distance travel via Midland? (A direct tram from Nunnery to Midland might cover that.that)
DynamicSpirit
12 Apr 2012
SE London
How tight are the pressures on the northern approach to Midland? If swapping Retford line services to Victoria made a difference to how many trains you could run/the reliability of trains to Rotherham and Barnsley, etc. then I could see a good case for doing that. But it would only work if you arranged for rail tickets to be valid between the station and Nunnery Square on the tram and - like you say - had direct Nunnery Square-Midland trams [*], and even then it would make making connections harder. If you could go a step further and make rail tickets valid on the tram between Cathedral and Nunnery Square, you could actually create a substantial benefit for Retford line passengers, making it easier for them to get into the town centre. A decent dedicated walking route between Midland and Victoria would help too for rail connections (1km - about 10 minutes for a moderately fast walker, so wouldn't appeal to everyone).
I suspect the answer is: If you planned it properly, you could get a net benefit from switching Retford services to Victoria - but if you didn't plan it properly, it could be disastrous, causing traffic on the Sheffield-Retford line to plummet.
[*] Didn't there use to be direct Meadowhall-Halfway trams, or have I misremembered?
Meerkat
14 Jul 2018
Or just quadruple the northern approach to Midland! It will surely have to be done at some point anyway.
