Chorley from Wigan Season Ticket
Discussion in 'Fares Advice & Policy' started by Mulberry2016, 11 Jan 2017.
Thread Status:
  1. Mulberry2016
    Mulberry2016 Member
    39
    25 Sep 2016
    Hi
    Just wondering if a season ticket from Wigan to Chorley would be valid via either Bolton or Preston. Both seem to be the same distance to me but via Preston would be easiest.
    Thanks
  2. roversfan2001
    roversfan2001 Member
    872
    19 Feb 2016
    Lancashire
    It wouldn't be valid via Preston because that would involve a doubleback through Leyland.
    Sent from my HTC Desire 530 using Tapatalk
  3. Mulberry2016
    Mulberry2016 Member
    39
    25 Sep 2016
    Would it be valid via Leyland then?
  4. Romilly
    Romilly Established Member
    1,362
    5 Nov 2013
    Yes.
    Although NRE shows journeys via Preston as valid for a Wigan-Chorley ticket despite the routeing guide easement that says otherwise:
    Or does this only apply where Leyland is the origin/destination of the journey?
  5. roversfan2001
    872
    19 Feb 2016
    Lancashire
    Without consulting the Routeing Guide I would hazard a guess that it is.
    Actually, upon checking NRE, it is giving itineraries via Preston, including the doubleback. It is also giving itineraries via Bolton and Leyland too. Although there are no easements allowing this doubleback so this seems like an anomaly.
  6. Mulberry2016
    Mulberry2016 Member
    39
    25 Sep 2016
    Thanks, guys. It would be much easier for my friend to get a VT to Preston from WGN and then on to Chorley
  7. Indigo2
    Indigo2 Established Member
    2,982
    16 Apr 2010
    Reading
    If you change at Leyland then it is valid under the shortest route rule. If you change at Preston then it is valid because:
    Wigan North Western is a routeing point itself (technically a member of Wigan Group)
    Preston passes the fares check as a destination routeing point for a Wigan to Chorley journey
    Preston to Chorley is a valid local journey in itself (through train)
    The Virgin train from Wigan to Preston follows a valid mapped route between those two routeing points.
    Because the mapped route and the local journey are validated in separate steps, the doubleback is irrelevant.
  8. Mulberry2016
    Mulberry2016 Member
    39
    25 Sep 2016
    Great stuff. VT to Preston it is then. Many thanks for that, pal.
Thread Status:
Share This Page
