Circuit clips and detonator
Discussion in 'Infrastructure & Stations' started by 387star, 24 Nov 2011.
Thread Status:
  1. 387star
    387star Established Member
    5,457
    How do track circuit clips actually turn a signal to danger? Is it by short circuiting the absolute block? How does it fool the signal into thinking there are wheels on the line?
    Why are detonators placed. Is it where there are automatic signals and/or the signaller can't make contact? Why are additional detonators placed by signal boxes?
    Thanks
    Rail Forums
  3. ralphchadkirk
    ralphchadkirk Established Member
    5,764
    20 Oct 2008
    Essex
    Track circuits clips short the track circuit, which causes the the circuit to display occupied. Trains do the same, thus TC's are failsafe.
  4. Wyvern
    Wyvern Established Member
    1,573
    27 Oct 2009
  5. brillopad
    brillopad Member
    115
    5 Feb 2011
    How do clips work in an axle counted area ?
  6. ralphchadkirk
    5,764
    20 Oct 2008
    Essex
    They don't. As far as I know.
  7. brillopad
    brillopad Member
    115
    5 Feb 2011
    Is there an alternative ?
  8. swt_passenger
    swt_passenger Veteran Member
    20,118
    GSM(R) cab to signaller comms, or IVRS if GSM(R) not yet live.
  9. ChiefPlanner
    ChiefPlanner Established Member
    5,264
    6 Sep 2011
    Herts
    Track circuit clips and detonators - as final back up. AFTER communicating to the signaller by GSMR / CSR or whatever. Final protection after line blocked by communication.
    TC clips very effective (from one who has stamped them down in emergency a couple of times !)
  10. MrC
    MrC Member
    197
    20 Nov 2009
    Or, more likely, CSR/NRN. There's very little GSM(R) based (incl IVRS) stuff live yet. Also why, at least in the axle counter areas I know, there's extra lineside phones at regular intervals.
  11. swt_passenger
    20,118
    I'm just going by IVRS being used following Portsmouth Area resignalling with axle counters - so it isn't really a surprise that other methods are used elsewhere...
  12. driver9000
    driver9000 Established Member
    3,654
    13 Jan 2008
    Detonators provide an audible alert to drivers by exploding when crushed by the train wheels. Their use is much diminished now but at one time they were used at distant signals during times of poor visibilty. Today their use is to protect failed trains, possessions, hand signallers use them when holding a signal at danger and they are also used in emergency protection. Some signal boxes may still have operational detonator placers but I think these are few and far between.
    Track circuit clips don't work in axle counter areas as there are no track circuits for them to short out.
  13. MrC
    MrC Member
    197
    20 Nov 2009
    The vast majority of trains after the PARS implementation still use CSR. The GSM(R) base stations are live as they are over large chunks of the non-axle counter areas of the network but the trains haven't had the GSM(R) heads etc fitted yet. IVRS is a portable voice only GSM(R) handset available for use by non-CSR equipped trains (eg XC).
    AFAICT future axle counter resignalling such as Poole-Wool will retain CSR at least until full GSM(R) rollout over the train fleets has been completed.
  14. TEW
    TEW Established Member
    5,110
    16 May 2008
    Absolute Block being something entirely different, where there are no track circuits or axle counters. Only one train at a time is allowed between any two signal boxes with each train checked as it leaves a section to ensure it is complete and none of it remains in the section, the tail light being the indication that a train is complete. If an accident were to occur in an absolute block area which blocks the opposite running line then placing detonators may be the only method of protection, since a train on the opposite line may already have entered a long block.
  15. Old Timer
    Old Timer Established Member
    3,704
    24 Aug 2009
    Absolute Block sections do not normally have track circuits in the section.
    Track circuits may sometimes start at the distant signal, but in most situations are confined to the area from the Home signal berth to the Section signal.
    Where there is an Intermediate Block section, then the track circuits will extend from the berth track circuit at the Home signal to the IB Section signal.
    In the event of an incident affecting an adjoining running line, protection is by means of NRN, and then detonators.
Thread Status:
Share This Page
