Claiming a Refund on Virgin
blue sabre
6 Jun 2010
You can, but as another poster has pointed out, it may actually be better to send your tickets to London Midland instead (if you had an Any Permitted ticket).
What would happen if the ticket has been stamped by the guard? Doesn't it carry the service number? Couldn't LM then turn round and say 'speak to Virgin you didn't travel on our service'?
----Edit-----
By 'service number' I actually mean head code.
No longer here
----Edit-----
The stamp only shows the train actually taken, not the train the OP intended to take, which was cancelled.
trickyvegas
10 Dec 2009
Did you travel throughout the validity of your ticket from A to B, or did you abandon your journey due to disruption?
I completed the journey all the way through, I was unaware of the problem until I arrived at Piccadilly.
No longer here
As you've travelled and suffered a delay (and the ticket is therefore used) you need to contact Virgin, whose train I assume you took. Compensation will be as per their Passenger's Charter ad will be in the form of vouchers.
trickyvegas
10 Dec 2009
Many thanks, didn't want to send them to wrong place.
thedbdiboy
10 Sep 2011
You are not entitled to the refund if you knew about the disruption before buying the ticket. If you bought the ticket and then the train is delayed or cancelled and you decide not to travel, you are entitled to a full refund.
Can I just take the opportunity to clarify that if you buy a ticket which you cannot use at all due to disruption you are entitled to a full refund even if you knew about the disruption in advance - NRCoC condition 26 (a).
The main difference if you were informed of delays is that it can affect your right to claim compensation for a late arrival (under Passengers' Charter or Delay Repay) - in such cases it is common to stamp tickets 'delay advised'.
I'm a bit concerned at one or two TOC colleagues who would appear to advise otherwise......
island
30 Dec 2010
Can I just take the opportunity to clarify that if you buy a ticket which you cannot use at all due to disruption you are entitled to a full refund even if you knew about the disruption in advance- NRCoC condition 16 (a).
The main difference if you were informed of delays is that it removes your right to claim compensation for a late arrival (under Passengers' Charter or Delay Repay).
SET also told me otherwise when I sought to refund a ticket earlier this year, and it took some correspondence before they agreed to repay the £10 admin fee.
phil35
17 Nov 2010
Well, as discussed above I applied online for a full refund for my ticket on the LM website, and I've just had this response.
Thank you very much for your DR Web Form which I received on 07 November
2011.
Unfortunately, we are unable to reply to your comments as the 1200pm
service you mentioned is not actually one of ours. So, I have passed your
letter on to the right company's Customer Relations office for you.
I am sure they will contact you soon. However, if you would like to
contact them in the meantime, your file has been sent to:
Customer Relations Manager
Virgin Trains
85 Smallbrook Queensway
B5 4HA
Telephone: 0845 000 8000
I am sure they will respond to you shortly.
Yours sincerely
Lisa Nolan
Customer Relations Advisor
I wasn't expecting this, I thought we agreed LM would hand out the discount?
sheff1
24 Dec 2009
Sheffield
In post #26 you said you caught a LM train around 1400 to Watford. You had already said (post #18) that you were delayed for 4 hours after you arrived in Watford. This is the delay you should have been contacting LM about. They in turn should then refund 100% under Delay/Repay.
You latest post suggests you referred to the 1202 Virgin train instead ?
phil35
17 Nov 2010
We did arrive at Milton Keynes station for the 12.02 Virgin train (MKC-EUS), but the first available train that turned up was the approx 14.00 (no idea what time it was supposed to depart, but it actually departed around 14.00) LM service to Watford Junction. As we didn't have a TOC specific ticket we just jumped on that one, and then we ended up in Watford for another good few hours.
The delay leaving Watford was on the Overground though (granted we'd have taken a LM if it had turned up before the Overground finally got going) so I never even thought to contact LM about that. My instinct just told me to put down the departure time of when I was intending to travel (which was about 12noon).
So did I make an error in the online form then? With the mixture of Virgin (who I was intending to catch and never did), LM (who I caught instead, but then delayed me further) and the Overground (again delayed me further) I just ended up confused.
sheff1
24 Dec 2009
Sheffield
Unfortunately, yes. Claiming via LM you needed to quote the LM train which terminated at Watford but which would normally have run through to Euston.
Easy enough to get confused though. Don't think there is anything you can do now other than wait for Virgin to reply.
