Clarification needed
Caad12
3 Jun 2018
Gateshead
Morning all
If you've failed testing at Doncaster twice is it correct that you cannot apply to be a driver with ANY TOC again?
Read in various places that you can't but a driver I was speaking to recently said you can. Anyone?
Liam00086
11 Mar 2019
Morning all
2 strikes and you’re out unless they change the tests again
ComUtoR
13 Dec 2013
If you fail twice, then yes, you are no longer able to apply to be a Driver.
However;
The tests are reviewed periodically and if they are changed after the review, your 'lives' are reset and you may reapply and take the tests again.
Both answers are right :)
Stigy
6 Nov 2009
It’s also worth noting that although there is currently a ‘2 strikes’ rule, this isn’t set legislation or anything so in theory a TOC or FOC could change this to suit. I’ve yet to hear of this happening though.
Also with the enhanced/national standards, it’s not always a clear fail (you could fail to meet the higher standard but meet the national one) so worth clarifying you definitely have used both lives completely.
Stigy
6 Nov 2009
However;
This is how my lives were reset. Failed (albeit just the once), at stage 1 in 2011 but because they were changed in 2013 (I believe), I had two fresh lives.
Caad12
3 Jun 2018
Gateshead
Thanks for two great answers. I'll double check with Northern. As mentioned I've one chance left so it was a cursory question.
