Class 158s not starting
Discussion in 'Traction & Rolling Stock' started by hougtimo, 13 Feb 2012.
Thread Status:
  1. hougtimo
    hougtimo Member
    108
    28 Feb 2008
    Every time I'm in Hull Paragon there seems to be a team of people nursing at least 158. Yesterday evening it was two that appeared not to want to start.
    Is this commmon?
    Rail Forums
  3. 150222
    150222 Member
    1,002
    9 Jul 2011
    Are you sure they were matinence/fitters? Could they be the crew/the ISS lot doing the rounds?
  4. trentside
    trentside Established Member Associate Staff Senior Fares Advisor
    3,259
    14 Aug 2010
    The back cab
    I recently travelled on 158799, and it had a couple of failed starts at Lincoln. I believe (thanks to people on here) that the alternator was playing up as well, with carriage lighting dropping on and off.
  5. hougtimo
    hougtimo Member
    108
    28 Feb 2008
    Well the one I saw yesterday had no less than 6 hivizs around it while another was leaning out the cab window with the starter whirring away.
  6. deltic1989
    deltic1989 Established Member
    1,484
    21 Sep 2010
    I do remember hearing that 158s and 156s, don't fire first time when they are started.
    Any truth in this?
  7. Schnellzug
    Schnellzug Established Member
    2,926
    22 Aug 2011
    Evercreech Junction
    I don't see why that should be, with 156s certainly, since they're exactly the same engines as 150s, nd most 158s do as well, albeit slightly uprated. 158s do of course have more of a load on the electrics, with air con and so on, so it might be more of a drain on the nattery, i suppose.
    * Battery, not nattery.
  8. dk1
    dk1 Established Member
    8,212
    2 Oct 2009
    East Anglia
    156s are ok but by the sound of EMTs 158s deff not. They do eventually start & then sound ok, but it is fingers & toes crossed for a bit.
  9. TDK
    TDK Established Member
    4,126
    19 Apr 2008
    Wrexham
    When it is cold 158's are difficault to stact if the webasto (or equivelant) is not operating correctly
  10. depablo
    depablo Member
    30
    19 Dec 2010
    What engines are fitted to these?
  11. 150222
    150222 Member
    1,002
    9 Jul 2011
    Cummins 350/400hp.
Thread Status:
Share This Page
